a lil help please
Old Aug 1, 2007 | 02:10 PM
26 psi's Avatar
a lil help please
so i got a 3in tbe with tp and did the non fouler trick ant it dont work i even tryed 3 of them still pops cel is there anything more i can try thanks 03 evo evo 9 dv 26 psi 3in tbe with test pipe thanks
Old Aug 1, 2007 | 02:16 PM
Kdash106's Avatar
did u reset the ecu after u put the fouler on?
Old Aug 1, 2007 | 02:21 PM
26 psi's Avatar
yeah i forgot to state that sorry
Old Aug 1, 2007 | 02:26 PM
jenx1976's Avatar
just get the CEL fix from perrin... i have it on my VIII. ..15K miles with no problems....
Old Aug 1, 2007 | 02:28 PM
Kdash106's Avatar
^ try what he said, i haven't yet put my TP on, and gonna try it soon, hopefully it won't keep throwing a cel light. Would there be any other mod u have that could set it off?
Old Aug 1, 2007 | 02:43 PM
26 psi's Avatar
im not finding it on there site and that the only code im getting is the #2 02 sensor
Old Aug 1, 2007 | 05:32 PM
newbieEVO8's Avatar
Have you actually pulled the code to see what the code is?
I know that when I first put my exhaust on with the mechanical fix I threw a code within a few days.
I went to autozone and had them tell me what the code was and it had nothing to do with the exhaust it was the random misfire and all I needed to do was put some fresh plugs in.
I would check what the code is first before I did anymore purchasing of parts.
my .02
Old Aug 1, 2007 | 05:34 PM
chaotichoax's Avatar
26psi?
that's a lot dude
Old Aug 1, 2007 | 05:38 PM
26 psi's Avatar
the code it for o2 had it checked
why is 26 psi alot ?
Old Aug 1, 2007 | 06:27 PM
newbieEVO8's Avatar
26 psi for your mod level is way to much.
More than likely you are knocking like crazy and losing power.
I would suggest lowering your boost to at the most 22psi.
I really hope you are tuned for that.
Again, just my .02
Old Aug 1, 2007 | 06:58 PM
26 psi's Avatar
26 is only on race gas and yes its tuned 1%knock@26psi
