WHAT MPH is 8900 RPM in 5th gear in an evo 9???
i was just sayin that the stock speedo is not accutrate at that speed
even my gixxer 1k speedo is off when toped out using the gps the mph is much slower than on the stock speedo..
but nice top end run wth the evo though
copied this from another member in another section just for refrence
tire wear, and how off ur speedo is....
I have 255/45/17.... brand new in 5th gear at 8000 i "should" do 185mph...
the most i've done was 172 according to the gps... at 160 on the gps my speed read 170....
with the stock size tires i did 145 according to the gps and the speed read about 152.
after 130 the speedo seems to read quite a bit off...
421 whp on a mustang, around 500 on a dynojet
yea I have an 06 gsxr 1k too, thats way off, but thats a common problem with all bikes
Ok i hope you where doing this test on a closed road. If you did this on the highway you are the most dumbest person on here. AND YOU SHOULD GET BANDED FROM THIS SITE.
You know how many lifes are at risk when your doing this kinda test on public roads. Because you know damn well you did it on the street.
So is your car running yet?
