ACD lights when hot only
Old Aug 2, 2007 | 09:50 AM
jred321's Avatar
lately all 3 of my ACD lights have been coming on only on really hot days and only in stop and go traffic. most of the time it's fine but not always. fluid level is fine. yesterday, for example, i drove ~200 miles straight to upstate NY, no problems. then i started driving around town, bit of stop and go, stopping and starting before fully cooling, lights came on. i would just take it to the mitsu dealer but given where i am the closest one is not close. does it just get too hot and turn on the lights to let me know i can't switch its setting?
Old Aug 2, 2007 | 11:50 AM
4G63-KID's Avatar
i think i read somewhere when all 3 ACD lights are lit, the t-case needs to be serviced (i would guess at the dealer) but im not 100% sure
Old Aug 2, 2007 | 11:56 AM
jred321's Avatar
from what i've found on here it basically means "Problem with ACD." the most common cause is low fluid but others have found their pump on its way our or a wiring harness loose. as long as it doesn't mean "ACD is going to eat itself and cost me $3000" i'm ok with the lights being on. i don't know if that's the case or if other people have experienced the lights coming on only when it's hot out
Old Aug 2, 2007 | 12:56 PM
PessimiStick's Avatar
All three lights is the ACD computer equivalent to the check engine light. No way to tell what it means (unless you have the ability to pull codes from it), other than the fact that the ACD doesn't like it.
Old Aug 3, 2007 | 09:44 AM
jred321's Avatar
reset my comp last night. today isn't as hot, i've driven ~40 miles since resetting and still the lights are as they should be though my CEL did come back on but that's expected
Old Aug 3, 2007 | 11:40 AM
prj.evo's Avatar
Go to mitsu and see what they say. Although that might be a worse idea..
Old Aug 3, 2007 | 12:57 PM
jred321's Avatar
if they were closer i would. it's 40 miles each way to the closest dealer which is a PITA. if it consistently returns i'll have no choice though
