Turbo timer, countdown??
Old Jul 31, 2007 | 09:12 PM
nx302stang's Avatar
What times do you set your countdown on the turbotimers? Mine is set to 40 seconds on normal driving, and a minute if i drive it fairly hard. Any suggestions on what to set the times at?
Old Jul 31, 2007 | 09:17 PM
JDMCT9MR's Avatar
Does your turbo timer have a setting to automatically calculate the needed cool down depending on your driving instead of having a pre-set time?
Old Jul 31, 2007 | 09:18 PM
m4tt VIII's Avatar
I just installed mine and was wondering the same thing. I let it go for a minute and I didn't boost at all. Theres really no harm I guess in letting it cool down for more than it needs.
bump
Old Jul 31, 2007 | 09:25 PM
nx302stang's Avatar
It has that setting, but I have a 20 mile commute to work, and by the time i get to work, it wants to cool down/idle at 10 minutes! it calculates the time from the alternator feed.
Old Jul 31, 2007 | 09:27 PM
jamerin's Avatar
I have mine set at 40 sec.... for the past year
Old Aug 1, 2007 | 05:39 PM
JDMCT9MR's Avatar
I have the HKS Type 0 which runs off the cars voltage output.It maxes out at 5 min.I guess like it says above any cool down is not gonna be bad for your engine.If I drivce about 20 miles on the freeway, I usually see about a 2-4 minute cooldown depending on how I am driving.Your settings should be fine though.
Old Aug 1, 2007 | 05:46 PM
eponti's Avatar
set mine at 1min
Old Aug 1, 2007 | 05:49 PM
sixers0307's Avatar
i have mine set at 30 sec normal driving and 3 min on hard driving/ long trips
Old Aug 3, 2007 | 01:47 PM
dsm2nrs's Avatar
Mine hooks up to the front o2 sensor it times pretty reasonably. Also my plx w/b has an output signal simulating a front o2 so I just hooked it up to that. Either way I turbo time 1 min+ when the car has been boosted 20-30 secs. Non water cooled turbo though.
