MBC problem, not a leak, but sucks just as much
Old Aug 3, 2007 | 05:52 PM
VtexGt3's Avatar
so i return from my quest. no luck. moved the tubing to the turbo nipple. took everything apart, tighten it all down. Still same problem. Sounds like its coming from the MBC the whinning sound... possible that the spring got too compressed? should i turn it in a few turns and see if it makes a difference? It sounds like the sound a really fast spinning ball bearing makes.
Old Aug 3, 2007 | 10:17 PM
Luis@TTP's Avatar
so you have it hooked up to the wastegat and the turbo nipple the one that sticks out the side goes to the wastegate and the one thats inline goes to turbo nipple. and still at 13 psi with a whinning noise. did you check for a boost leak and make sure your wastgate arm is attached i have had one flapper arm pop off. if thats how its set up i would change the spring in the boost controlle to the stiff spring.
Old Aug 4, 2007 | 06:12 AM
VtexGt3's Avatar
i'm gonna run one last test and it'll have it down to either a leak for sure or if its the mbc... reattaching the original tubing and putting it back to the stock control.
Old Aug 4, 2007 | 06:32 AM
gixxerman11's Avatar
hey
we do people t it off its just more stuff you should have used the tubro outlet nipple instead of capping it off i have the same one works great
Old Aug 4, 2007 | 11:05 AM
evo150's Avatar
have you tried taking the mbc apart and cleaning it?
Old Aug 5, 2007 | 09:10 AM
VtexGt3's Avatar
rerouted it to the turbo nipple, took apart all the tubing and IC piping and redid everything, took apart the MBC and put it back together, works perfectly now... so in the end, didn't know where the problem was since i did all of that in one shot, but the problem is fixed! Thanks alot to everyone who helped!!
and the tune from TTP works great!!
Old Aug 5, 2007 | 03:07 PM
Luis@TTP's Avatar
your welcome glade your happy with our tune
