ugh ohh boost creep
Old Aug 6, 2007 | 09:53 PM
pbsis's Avatar
ugh ohh boost creep
Well I hope I am not one of the unlucky ones who is suffering from boost creep because of an ebay o2 housing. First things first here is the EBAY o2 i purchased
http://cgi.ebay.com/ebaymotors/ws/eB...142756472&rd=1
I am using a hallman pro rx to controll boost. Before all this when the car was stock i was seeing around 1.2-.3 bar in 3rd and 4th gears. Now I am seeing .9 or 1.0 bar till about 5500 when the boost will begin to creep up to 1.4 in 3rd and 1.5 in 4th. I have the boost controller turned almost all the way down. I have heard of ppl adjusting the wastegate to tapper the boost creep and was wonder how to go about that. Is it just a nut on the top of the waste gate that I should loosen.
thanks
Paul
Old Aug 7, 2007 | 06:04 AM
spln*up's Avatar
my ebay o2 used to do the same. it will start at 20psi and by 5500 it will go to 24psi!! crazy stuff. i took it off and now run the stock one.....all even now.
Old Aug 7, 2007 | 06:12 AM
pbsis's Avatar
ugh i would like to avoid that as they are such a pain to install. Anyone have any ideas about the waste gate adjustment
Old Aug 7, 2007 | 06:46 AM
OTTOMITSU's VR4's Avatar
The solution seems to be enlarging the wastegate dump hole within the actual turbo outlet pipe itself.
I had no problems with my Megan housing, but have heard about some people having issues with the ebay ones and boost creep.
Old Aug 7, 2007 | 06:55 AM
UpstateEVOVIII's Avatar
Clifton Park huh...I've never seen on you here. Hit me up on PM.
Old Aug 7, 2007 | 06:57 AM
To adjust the WGA you need to first remove the pin from the arm to the housing, then loosen the nut, turn the rod to reduce pretension on the wga, reattach the rod, install pin, tighten nut. continue to do this until you notice your boost come back down. I'd just bring it pretty much as far loose as you can and set it, that way you should avoid further issues if heat is an issue in your area.
Old Aug 7, 2007 | 07:04 AM
pbsis's Avatar
Ok great thanks for the advice. I am aware of ppl having some creep issues with ebay o2's but mine had the hole fairly large. It wasnt restrictive.
Anyway i am going to try the WGA adjustment first
Old Aug 7, 2007 | 09:06 AM
uglyevo's Avatar
If there is room to port out the O2 housing hole then port it out. Make it as big as you can w/out ruining it.
I don't know why you would want to mess with the WGA if it wasn't a problem before you put on the O2 housing. loosening it will only make boost less responsive as the flapper will open more easily now.
Old Aug 7, 2007 | 11:39 AM
Kevindanger's Avatar
This is true make that hole as big as you can or weld a dump pipe on it
Old Aug 7, 2007 | 11:55 AM
pbsis's Avatar
I dont even want to take the chance of having to take off the housing and then put it back on only to hope i ported it enough. I am just going to order the TTP housing. No boost creep with those right.
I was going to adjust the WGA but uglyevo is right. It was working fine before and will makethe boost less responsive. Kinda lose lose situation.
Old Aug 7, 2007 | 12:06 PM
deadbeatrec's Avatar
all u damn guys from the albany area always leavin me out of everything. haha. 19th mother ****ers, kohles plaza on central. be there!!!!
Old Aug 7, 2007 | 12:14 PM
EVIL_EVO_VIII's Avatar
I had boost creep problems also with the Megan unit but only in the winter in cold weather. I get 0 boost creep now. We'll see what happens this year when it gets cold again. Should be better for me now bc im not holding boost that good since i put Cosworth cams in
dierr
11
Jul 3, 2014 09:18 PM
ProjExtremis
Mar 5, 2014 12:09 PM
millsyy17
28
May 24, 2010 05:26 PM
TwistedEvo8
15
Oct 4, 2009 05:58 PM
