BOV adapters for EVO8s
Hi guys.
I'm not sure if any other company makes Evo 8 specific flanges, but I couldn't find any. They always came with the BOV kit. I already had a Greddy BOV from my Audi that I wanted to use on the EVO and found this website that sold just the adapters. Just wanted to pass along the info.
HKS & Greddy adpaters
nonhero,
The guys (ATP) are in Fremont, CA so I just went there to pick up the BOV flange. I treid to install the Greddy Type-S but the flange's tube is a bit smaller than the stock!
I returned it so I'm now looking for another place to get it. Found this place: http://www.horsepowerfreaks.com/Show...ategoryCd=MOUN
Also, do you know if the Greddy's Weld-on flange (part number 11900450) would work?? The diameter of the tube looks bigger tho...
you'll still need a flange to make the 1G BOV fit.... if you can find a 1G bov for cheap, thats a good idea, but even the 1G BOV will leak at around 19-20psi unless you crush them. Road Race sells an uncrushed 1G bov for $99, not that much cheaper IMHO......
Part support and price would be a lot easier and cheaper for a 1G Compressor Bypass Valve than an aftermarket BOV.
http://www.diamondstarmotorsport.com/intakeparts.shtml
They are on there for $86 and you could probably talk Nate into hooking you up with the flange for pretty cheap. He is a good guy. Lots of people ditch their 1G DSM stock pipes at his shop and get the Dejon intake pipes, so I am pretty sure he has a few flanges laying around. Another bonus of running a CBV over a BOV is that you don't have any issues with idle like you do with a BOV. These cars are meant to run CBV's unless you scrap the MAS and go with some other form of air metering.
You can also fund 1G DSM CBV's on www.dsmtrader.com for about $50 uncrushed.
Josh
Josh
Originally posted by 90GSX-03EVO
Does it dump to atmosphere or does it replumb into your intake track after the MAS?
Josh
Josh
Originally posted by timzcat
Recirc and drop in replacement. Believed by may to be the best valve for the Evo. Simple design that works. You know the saying KISS.
Josh
If you want to adjust the Forge you just change the spring. Only necessary if you put it on and it is not smooth on release. Or if you want to up the boost.
They are starting to sell them with the spring kits so if you need or want to change springs you already have them. Plus they warranty them for life, I am pretty sure.
