In need of some help, please. NOISE
Okay, I'm sorry but it's another noise question.
I have this grind, click, I hate to do this but like a kkuuhhrr. sound. you can try to sound that out
when I let the clutch out. worse time in 1st but doest it through all shifts.
A little backround. I had the 5th gear synchro done a while back they broke the axle seal. Later I had this weird clunk noise and they said it was my trans mount. they tightened it up and it was gone.
Later I noticed a fluid stain on the rocks I saw some fluid while I did my suspension they said that the axle seal was leaking. I haven't any noise sounds probs until now.
This sound is getting worse and is worrying me. I am tired of taking it to these people.
it seems to do it more with the wheel turned. I let my friend listen to it and he said sounds like something is under pressure and rubbing against something so hard that its "jumping" across the surface. But he knows more about american cars than mine.
If any one has any idea or needs to know something else that maybe would explain it a little better. Please let me know.
Thank you
community
Buddy
when I let the clutch out. worse time in 1st but doest it through all shifts.A little backround. I had the 5th gear synchro done a while back they broke the axle seal. Later I had this weird clunk noise and they said it was my trans mount. they tightened it up and it was gone.
it seems to do it more with the wheel turned. I let my friend listen to it and he said sounds like something is under pressure and rubbing against something so hard that its "jumping" across the surface. But he knows more about american cars than mine. If any one has any idea or needs to know something else that maybe would explain it a little better. Please let me know.
Thank you
community Buddy
this was a dealer that fixed it for me.
update me and my uncle looked around and have found that the lower mount behind the engine isn't loose but the through bolt that goes under it is. It is very difficult to see from the top. Does anyone have a schematic of this bolt. what size.. or if you know what Im talking about the easiest way to get to it.
I'm sick of this I'm doing it this time.
jackfrog
20
Aug 22, 2014 06:49 PM
MagicManRed
17
Oct 3, 2011 08:36 AM
