Can I use this in my ACD?
http://www.c66racing-synthetics.com/...tins/ATFPB.htm
Amsoil Synthetic ATF
Can this be used in my ACD?
Should this be done at the same time as changing my trans fluid, transfer case and rear diff?
i use amsoil synthetic manual transmission fluid 75w-90 gl-4 in my tranny http://www.c66racing-synthetics.com/...tins/MTGPB.htm and only stock diaqueen in my front transfer case and rear differential.
Because I was trying to order all the fluids online and avoid driving 45 minutes to the dealer. So not knowing the name and/or brand it calls for made it kinda hard to find. All I was told was ATF III, never having owned an auto, I don't know much about ATF. I ordered the other fluids that you suggested, thanks for that.
OEM fluids only in the transfer case and read diff... even on built trannies this is what they suggest...
as far the gearbox is concerned people have tried other lubes other than OEM with success like Redline MT90, Penzoil, etc etc...
I know you're suppose to use OEM Mitsubishi GL5 LSD EVO Gear Oil Diaqueen (for the 5spd tranny) Transfer Case and Rear Differential, but what is OEM Tranny Fluid? IS BG Syncroshift at Lancershop any good?
