possible to reuse heat wrap? what if i soak it before removing?
Old Aug 10, 2007 | 08:16 AM
fyreant's Avatar
like the title says.. is it possible to reuse header type heat wrap if you soak it in water before removing?? it is not silicone coated.. AND I ALREADY SEARCHED AND FOUND NOTHING! LOL
Old Aug 10, 2007 | 12:18 PM
fyreant's Avatar
bump
Old Aug 10, 2007 | 12:24 PM
jenx1976's Avatar
if the materials are intact, should be ok...i think.
Old Aug 10, 2007 | 12:35 PM
C6C6CH3vo's Avatar
Just don't inhale as you remove - that stuff gets into your sinuses and trote precipitating cold/allergy symptoms
Old Aug 10, 2007 | 01:48 PM
fyreant's Avatar
^^ thanks for the advice.. reason i ask this is about a month or so ago i put a new downpipe on and wrapped it and now i need to take it off and get a UEGO bumg welded into in and dont wanna spend another 50 bux on header wrap if i can re-use it. i fugured you probably could as long as you dont try to take it off dry...
Old Aug 10, 2007 | 01:56 PM
mifesto's Avatar
yes unless its burnt or physically damaged i dont see why not
Old Aug 11, 2007 | 11:28 PM
fyreant's Avatar
job completed! heat wrap was EASILY re-used when re-moistureized and made the job a sinch!
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
beetle_orange
Dec 11, 2015 08:00 PM
ChrisVIII
Feb 7, 2012 10:58 PM
DJAfterShok
10
Feb 22, 2011 08:55 AM
BUCKNAKED
Nov 16, 2005 03:03 PM
