white smoke /low oil
Old Aug 10, 2007 | 12:41 PM
Blackie9900's Avatar
hey, i ve got an 03 evo , tve exhaust lala llala lal,
basically ive noticed that it blows whitish smoke out the exhaust, and at idle and it gets worse at wot, when i check the oil, its always low, and when i take off the intake pipe their is always oil there, i was wondering wat i can do to fix this problem , ty
Old Aug 10, 2007 | 12:43 PM
AJsGenerX's Avatar
My guess would be a headgasket.
Old Aug 10, 2007 | 12:46 PM
meckert's Avatar
Wht smoke head gasket....grey/blue smoke oil..
Old Aug 11, 2007 | 09:24 AM
that was my guess too, gna go to a compression test today , i was also reading something bout the pvc valve
Old Aug 11, 2007 | 11:17 AM
SteelEvo's Avatar
blown turbo seals
Old Aug 11, 2007 | 12:57 PM
so.. to fix it get a new turbo?
Old Aug 11, 2007 | 01:45 PM
yea, its the turbo , not the head gaskit
wtb turbo pst
Old Aug 13, 2007 | 01:55 PM
milo's Avatar
Do a compression check you could be gettting some bad blow by and if that is the case. You'll be needing a rebuild due to worn out rings. How often do you have to add oil and much oil do you lose?
Old Aug 30, 2007 | 06:13 AM
GotBoOst05's Avatar
i also burn alot of oil.........
Old Sep 3, 2007 | 07:52 PM
fox2boost's Avatar
hows the coolant look?
Old Sep 3, 2007 | 08:34 PM
cfdfireman1's Avatar
duh
Originally Posted by SteelEvo
blown turbo seals
pull a hose off the intercooler if it's got oil in it it came from the turbo seals. just to be sure pull the hose off the turbo intake if that's dry for sure it's the turbo.
Old Sep 3, 2007 | 09:25 PM
cpoevo's Avatar
A compression check cannot properly diagnose the problem. It will just tell you there is a problem. In order to find the problem you have to do a leak down test. The leak down test will let you know if it is head gasket, exhaust valve, intake valve, or blowby the piston rings. Do not diagnose an engine on a compression test alone.
Old Sep 7, 2007 | 08:20 AM
06ebgsr's Avatar
I would say check the turbo first then work your way to the headgasket....
Old Sep 7, 2007 | 08:33 AM
suekie's Avatar
did you check the coolant? Drain it and see if there is alot of oil in there. When you get a bad headgasket, you either get oil in your coolant, or coolant in your oil. Since you are blowing out white smoke, it would be oil in the coolant.
Old Sep 21, 2007 | 10:00 PM
MitsuJoe's Avatar
do a compression test
have you been tuned?
