Evo IX walbro inline pump install ???
Old Aug 15, 2007 | 10:52 AM
uglyevo's Avatar
Just wondering if anyone has installed an inline pump on their evo. If so where did you mount it and where did you power it from? Did it fit with the stock lines?
Old Aug 15, 2007 | 10:56 AM
impreza2darksyd's Avatar
Am wondering about that too.
TeStUdO's Avatar
Have you tried just using 2 in tank Walbro's? I think thats alot easier than installing an inline pump.
Old Aug 15, 2007 | 10:58 AM
uglyevo's Avatar
Already have the inline pump, and I don't think it should be that hard, just wanted to hear from others before I start the install.
Old Aug 15, 2007 | 08:13 PM
uglyevo's Avatar
bump
Old Aug 16, 2007 | 03:51 AM
nianlala's Avatar
I have a intank Buschur HO pump feeding an inline Bosch 044 pump. Gives me enough fueling to run 33psi on my GT35R on 93 pump.
The ext pump in mounted just in front of the fuel tank and feeds back in to the stock lines. There is enough room there to tuck it up and out of harms way.
I used this setup as a twin intank solution is not available for an Evo 4.
The only downside is that the Bosch 044 is quite noisey and can be heard outside of the car quite easily when at idle, and can also be heard inside the car - small price to pay for performance I say.
I have heard that some people with the same setup have fixed the external pump to the firewall.
With regards to powering it up, my tuner made up a seperate relay that runs the pump directly from the battery.
Speed Element
EvoX 'For Sale' External Engine / Power
415
Jun 9, 2016 01:31 PM
Speed Element
Feb 17, 2010 12:27 PM
silverofs
48
Oct 11, 2006 12:34 AM
SlowCar
May 9, 2005 05:02 AM
Ryan Bush
Lancer Aftermarket Forced Induction Tech
Aug 8, 2004 10:27 PM
