fuel pump and injectors
If you plan on upgrading the injectors there are some things to consider before picking a size. What turbo do you run now and do you plan on upgrading to something slightly bigger or way bigger later? Are you going to stick with the stock ecu? Are you going to run race gas often, as this usually means you will be cranking up the boost therefore needing more injector. These are all things to consider but, for now if you are on the stock turbo your stock 550's are fine.
Pm me if you are interested in either the fuel pump or injectors or both.
mrfred
E85 / Ethanol
Apr 17, 2008 09:25 PM
