For those removing A/C
Old Aug 19, 2007 | 01:46 AM
justchil's Avatar
Are you removing the condenser fan or leaving it?
Old Aug 20, 2007 | 03:05 AM
justchil's Avatar
I'm going to go with removing it.... the only pics I found show it removed
Old Aug 20, 2007 | 04:00 AM
gudmundur's Avatar
I removed the condenser fan.
I had a hard time finding a belt that was suiteable .. atm I have a 1463 on .. but have a 1475 on order.
Old Aug 20, 2007 | 04:26 AM
justchil's Avatar
That's not good. I already cut my current belt to get it off quickly lol.
I was under the impression you could be an RS belt from a dealer. Kinda expensive but if it's a perfect fit....
Old Aug 20, 2007 | 04:28 AM
gudmundur's Avatar
From what I understood from my dealer the rs belt is 1443 (as far as I remember)
And that belt wouldnt fit my car atleast.
Some of the pulleys must be smaller on the RS car
Old Aug 20, 2007 | 04:49 AM
justchil's Avatar
Hmmmm I wonder what I should do.... I'm in no hurry so maybe I'll wait to see how the 1475 belt works for you.
Old Aug 20, 2007 | 04:51 AM
gudmundur's Avatar
I know that the 1475 belt works.
A friend of mine has already done the AC delete and he is using the 1475
Old Aug 20, 2007 | 05:35 AM
justchil's Avatar
Do you happen to have an exact part number i can use on mitsubishiparts.net or something similiar? Thanks!
Old Aug 20, 2007 | 04:16 PM
justchil's Avatar
I'm going to try MN158795
Old Sep 29, 2007 | 05:37 PM
PPI's Avatar
PPI
Does anyone know the length of this belt? Trying to find one this weekend so that means no dealership and the parts stores don't show it. The belt for a/c is 70.5" long 6 rib for reference.
Old Sep 29, 2007 | 08:11 PM
justchil's Avatar
It worked for me! 2003 EVO8. Granted u could go find one at a local parts store cheaper I'm sure...
Old Sep 29, 2007 | 09:09 PM
0100's Avatar
Veteran: Army
Does anyone know if the MN158795 will work on a IX engine?
Old Sep 30, 2007 | 01:51 AM
gudmundur's Avatar
Hi
Best length that I found here locally was a 1475 6rib belt
regards
Gudmundur
Old Aug 6, 2008 | 11:01 AM
JohnBradley's Avatar
Factory short belt is 1446mm and the long belt is 1793mm
P# for the short belt- MN158795
Old Aug 6, 2008 | 12:02 PM
jmartinez1170's Avatar
i took it all off even p/s
GSC sells the gates belt for ac delete
