For those removing A/C
Old Aug 6, 2008 | 12:05 PM
Ev0cRaZy's Avatar
Look up one of Paul Nelsons old threads is where I found the part # from Napa for no A/C belt
Old Aug 6, 2008 | 12:56 PM
DemNYboys's Avatar
From: in a place I dont want to be BUT here so you and I can be free!
thanks for the confirmation of the part numbers on the belt...Im on the way to order one right now.
Old Aug 10, 2008 | 07:33 AM
downshift411's Avatar
check paul nelsons post. results may vary. then check my post.
i found this out on napa online
2004-2006 >> Dodge >> Stratus >> 2.7 L 167 CID V6 DOHC 24 Valve
Belt - A/C & Alt
Item#: NBH25060563
Price: $16.29
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Product Features:For Replacing Original Belts on Serpentine Drives & Other V-Ribbed Applications. Designed for Smaller Dia. Pulleys
Backside Idlers & Use w/ or w/o Automatic Tensioners. Eliminates Belt Noise
Reduce
Imperial Length:56.875" (1445mm)
Top Width:.807" (20mm)
# of Ribs:6
i bought the same belt as paul refered but specs was a lil different(longer) i needed 2 inches off!!! this will suit me fine. im gonna go and check it out...(results will vary because i got a JDM MOTOR).
Old Aug 10, 2008 | 05:43 PM
well since this belt is exactly like specs as the dealers. i tried it and its too short. *** mee
Old Apr 29, 2009 | 08:57 PM
fixem2's Avatar
What belt ended up working? My compressor is out and I would like to bypass it temporarily until I find a replacement.
Old Apr 30, 2009 | 06:56 AM
justchil's Avatar
MN158795 worked for me
Old Apr 30, 2009 | 08:13 AM
fixem2's Avatar
Do you know the length? I was going to order the Appropriate Goodyear belt. Did you do anything else when you used it, remove the compressor and lines, etc...
Old Apr 30, 2009 | 09:51 AM
justchil's Avatar
I wish I would have measured mine... I went with OEM just to save the hassle. I removed my complete A/C but I would imagine you could leave everything there just bypass the pulley.
Old Apr 30, 2009 | 10:08 AM
fixem2's Avatar
Appreciate the input. If I find the dimensions I will post them here
Old Apr 30, 2009 | 07:53 PM
fixem2's Avatar
Looks like my problem was caused by a broken sensor connector plug. Put back on with Zip ties as a temp fix. Stupid car!
imdrax
Apr 1, 2020 09:45 AM
heliarcpro
Feb 26, 2017 01:59 PM
bvliz
Nov 14, 2016 01:18 PM
JRally
May 22, 2016 04:22 PM
impact blue
Mar 18, 2016 09:54 AM
