Full Fluid Change. Fluid Suggestions.
Old Aug 23, 2007 | 01:51 PM
  #31
BBYBruno's Avatar
Originally Posted by Pure Playaer
now if i go to mitsubishi and tell them i want 1 quart Redline Heavy Shockproof, and 1.0 ounce of Redline LSD Additive, will they be able to do it for me? and will they do it? like mix the fluids?
Well Mitsu does not stock Redline products, but the labor part they could do.
Old Aug 23, 2007 | 09:11 PM
  #32
Pure Playaer's Avatar
i got all the stuff you suggested except im going to use OEM tranny n xcase fluid
thanks alot for the help everyone
Old Aug 23, 2007 | 09:18 PM
  #33
Danny23's Avatar
BG2 in the trans.,stock diaqueen in the t/case and diff,mobil one 10w 30 in crankcase. PERIOD!
Old Aug 23, 2007 | 09:52 PM
  #34
riceball777's Avatar
motor = 5 quarts mobil 1 10-30
tranny= 2 quarts redline mt90 1 quart redline mtl
t case = .5 quarts oem mitsu diqueen
rear diff= .5 quarts oem mitsu diqueen
Old Aug 23, 2007 | 10:23 PM
  #35
sparky's Avatar
My Recipe:,,,,Rear Diff: 1 quart Redline Heavy Shockproof w/1.0 ounce of Redline LSD Additive
Transfer Case: 1 quart Redline Heavy Shockproof
So, how do you manage to get 1 quart each into the TC and rear diff.?
Old Aug 24, 2007 | 06:18 AM
  #36
rcheung's Avatar
Many members have reported that after using BG syncroshift they noticed an increase in metal particles during the oil drain. Its probably because BG is so thin it does not protect as well. It shifts great though. I used to use BG myself for about 30000 miles and they only problem is an occasional second gear grind. I switched to straight redline MT90 and have not had a gear grind yet. Its only a tad bit tougher to shift with the redline.
Old Aug 24, 2007 | 07:36 AM
  #37
BBYBruno's Avatar
I don't, I put down what you need to buy, you know what I mean?
Old Aug 24, 2007 | 07:38 AM
  #38
Thanks for the help bruno i bought all the stuff u suggested.. but instead of using like 1/3 of the LSD addative, i told wrote down for mitsubishi to use half the bottle of addative, and the rest the heavyshock stuff
Old Aug 28, 2007 | 07:41 AM
  #39
BBYBruno's Avatar
No problem. Let me know how the car runs after you get everything installed.
Old Aug 28, 2007 | 07:43 AM
  #40
Actually we got everything installed on friday last week, and it was of course done same day.. She said the car ran MUCH better after the change of fluids.. The idea of adding lsd addative was smart, and mitsubishi didnt have a problem doing it
Old Aug 28, 2007 | 07:49 AM
  #41
BBYBruno's Avatar
Awesome i'm glad everything worked out. Did you end up using any OEM fluid? You said you might use it in the tranny. Oh and did you change the coolant?
Old Aug 28, 2007 | 07:50 AM
  #42
tiffany&coNY's Avatar
yup, it did and does run a lot better. In fact, some of the noises it was making, stopped and it's continuing to run very smoothly. Let's hope it stays that way.
+1 on the thanks for the help
myself, and the evo really appriciate it.
Old Aug 28, 2007 | 07:51 AM
  #43
Yups, we did redline 10w30 in the engine and reline rear diff stuff + half bottle lsd addative.. no clutch/brake fluid. and OEM fluid for tranny and transmission
probably for my personal car when i get my tranny fluids changed i might do Redline as my cars racing and going to be continously raced
Old Aug 28, 2007 | 07:52 AM
  #44
BBYBruno's Avatar
I noticed that too. A lot of the decel noise and misc. drivetrain noise went away or got quieter.
Old Aug 28, 2007 | 07:53 AM
  #45
Babe you need to L2 +1
Its ok ill teach you later
