Full Fluid Change. Fluid Suggestions.
Old Sep 23, 2007 | 10:22 PM
  #61
Silver Knight's Avatar
Originally Posted by rcheung
I used used redline water wetter once and would never ever use it again. It doesn't last every long. I noticed no difference in coolant temps when I used it. In less than a year it turned to brown oil which I though was a blown head gasket and had a really hard time getting it all flushed out. There is also a mega thread on water wetter with people that had similar experiences to mine.
Water Wetter Review
Old Sep 24, 2007 | 04:43 AM
  #62
rcheung's Avatar
Originally Posted by Silver Knight
I've read all the reviews on water wetter on evom , whats your point? Did you use it and have experience with it or are you just trying to post a water wetter thread?
Old Sep 24, 2007 | 06:29 AM
  #63
kingman4's Avatar
Clutch bleeding...
brakes should also be bled if they feel squishy
Old Sep 29, 2007 | 09:42 AM
  #64
I was simply backing up your point. Why is everyone so defensive on this friggin' board. Sheeesh!
Old Oct 20, 2007 | 08:06 PM
  #65
Zodiac13's Avatar
anyone have a link on how to change the Rear Diff fluid i have found all the other ones and already finished but can't seem to find this one. thanks.
Old Oct 20, 2007 | 08:13 PM
  #66
Exciting News's Avatar
There may be a how-to but it's so easy you don't need one. Look for two 24mm bolts on the diff. Intuitively, one (upper and facing the front of the car) is the fill while the one facing the rear is the drain. I have faith in your ability to figure it out.
Old Oct 20, 2007 | 11:25 PM
  #67
SPANKED's Avatar
Well I changed my tranny fluid with OEM Super Diaqueen and unfortunately I'm still getting the infamous 5th gear grind on my EVO 9 with 16,000miles... should I try syncromesh or just try to get it warrantied?
Old Jul 6, 2009 | 10:03 AM
  #68
josel_atr's Avatar
i know this thread is a couple of years old but ill revive it anyway.
i did a search on fluids because i will be changing mine. i got my evo @ 26k miles. i already did an oil change using mobile 1 oil. next will be the tranny and diff.
mitsubishiparts.net carries the oem replacement but i dont know if i can get those locally. shops carry redline fluids here in vancouver though.
how are your evo's now? did you stay consistent using the saame fluids?
Old Jul 9, 2009 | 02:23 PM
  #69
Boomer0822041's Avatar
good thread. thanks for all the helpful info.
Old Jul 9, 2009 | 02:53 PM
  #70
jmtx86's Avatar
back from the dead?
Old Jul 23, 2009 | 06:47 PM
  #71
zlthomason's Avatar
clutch n brake fluid = the same
Old Aug 3, 2009 | 01:32 PM
  #72
motta87's Avatar
i have a question, it might be stupid, but i rather ask before doing something that might damage my car.
i wan to change all the fluids on my evo 9 mr and after reading a lot of threads, it seems like red line and amsoil are the best options.
i cant get amsoil here in mexico, so im looking to buy red line.
my question is: would it be ok to use the red line mix on the 6 speed tranny?
because right when i was about to buy it, i read the description and it says (5 speed cars only)
this is the site: http://www.maperformance.com/redline...k-evo-dsm.html
Old Sep 7, 2009 | 12:18 PM
  #73
rn.evo's Avatar
bump this thread up, i was wondering if any of you guys have a picture of the drain and fill plug for the rear differential??
Old Nov 25, 2009 | 08:00 AM
  #74
Astro_Train's Avatar
Veteran: Navy
bump for good info... none of the original posters chimed in. As for oil, I'm using Mobil 1. I see everyone says 5 quarts for the EVO 8... I was told the IX only requires 4.5 quarts... can someone chime in and clarify this?
Old Nov 25, 2009 | 08:17 AM
  #75
chaotichoax's Avatar
it varies from person to person
because of the oil cooler the car takes approximately 4.8 qts when completely drained
kjcs9
Dec 23, 2015 07:41 AM
St1g
Aug 7, 2015 02:24 PM
ekizenbe
For Sale - Cars For Sale
25
Jul 8, 2014 05:02 PM
