**Dyno Results**
Old Aug 24, 2007 | 01:14 PM
boostedwrx's Avatar
You can still hit 22psi and have a boost leak.
Do a boost leak test!
Old Aug 24, 2007 | 07:04 PM
mac74's Avatar
I think very low. Look at my sig, An like the others do a boost leak test, you have to be losing power some were, my only difference is front mount but now way its like 85 whp???
Old Aug 24, 2007 | 10:14 PM
justboosted02's Avatar
10.1 afr is really really REALLY rich, lean it out and i bet you pick up a considerable amount of power, if you are running the maf still (which i assume you are) and you have a boost leak it will cause you to run rich and loose power. sounds like you need a boost leak tester
