Some Intercooler-Questions
Old Aug 28, 2007 | 09:34 AM
dawnduran's Avatar
Hi guys.
I plan to use a FMIC with LICP and UICP.
Which one is better for airflow and temperature?
The APS or the Perrin?
I like both of them. The Perrin is cheaper but the APS looks like better quality.
I want to use the SAMCO Intercooler-Pipe-Kit.
Had/Have someone one of these intercoolers or this piping kit?
How much does this intercoolers cool down the air (compare with stock)?
What can I expect in spooling and torque?
Thank you guys.
Old Aug 28, 2007 | 10:53 AM
accident's Avatar
you won't be able to use the samco's if you go with aftermarket pipes. why not just get a ETS fmic and pipe kit, probably cheaper then either one you mentioned, fit is perfect and has proven results. if you plan on keeping the factory airbox just get a lower pipe and keep your stock upic.
ed
Old Aug 28, 2007 | 11:10 AM
dawnduran's Avatar
Ok, then please tell me, wich LICP and UCIP-Kit is usable with the perrin or APS-Intercooler.
I like the APS and the perrin because the results to use these IC are great. You see that in many evolutionm-threads.
And I want to use the factory-crash-beam.
Old Aug 28, 2007 | 12:44 PM
travman's Avatar
any factory intercooler fitting piping kit........
ets, ams, buschur, neisi all would work.
Most good aftermarket pipe kits are short routed which will yield the best results but will require a mini battery or battery relocation.
Why would you want samco? if your doing a nice intercooler do a nice charge pipe setup with aluminum or steel pipes, good silicone couplers and T-bolts.
Old Aug 30, 2007 | 11:34 AM
dawnduran's Avatar
bump...
Do you know good aluminium upper pipes?
What do you think about the intercooler question?
Old Aug 30, 2007 | 12:25 PM
travman's Avatar
Nisei and AMS both make aluminum pipe kits but require the mini-battery or relocation. The cheaper alternative is powdercoated mild-steel which is what ETS sells.
I dont know anything about those intercoolers....but I could think of better alternatives that are proven like AMS, Buschur, Nisei, etc. But thats just my .02 cents...
I would also suggest if you do get an intercooler get one that has the piping kit made by the same company so everything works together and fits like a glove.
