ETS 57 trim Dyno Graph
Old Aug 31, 2007 | 10:33 AM
uglyevo's Avatar
Originally Posted by eve-slow
Ya bro. Nice numbers bro!.......bro
do you know who thats suppose to be?
Old Aug 31, 2007 | 10:41 AM
DS-03evo's Avatar
Sounds great...what did you put down on just pump gas?
Old Aug 31, 2007 | 09:13 PM
Duby's Avatar
yea, the first imitation wasn't to bad tll he forgot what else to say
Old Aug 31, 2007 | 11:32 PM
uglyevo's Avatar
didn't do one on pump since I was on E90. however another car with the same kit on the same dyno made 403whp on pump 92
Old Sep 1, 2007 | 03:29 AM
1mad evo's Avatar
i dont understand, is the torque at the wheels or the flywheel? because if its at the flywheel than its pretty low, i would have thought it to be at least 450 tq atf ???
Old Sep 1, 2007 | 08:34 AM
uglyevo's Avatar
torque has never been high on 50 trim based turbos in comparison to hp
Old Sep 1, 2007 | 08:45 AM
EvoDan2004's Avatar
and trq is lower yet then normal because of stock cams.
Old Sep 1, 2007 | 10:08 AM
EV0lved's Avatar
fuggin awesome
Old Sep 1, 2007 | 10:13 AM
scorke's Avatar
Did you do any straight pump pulls? Without cams or seeing other turbos or a pump gas number I am not sure if its making good numbers or poor ones...
Scorke
Old Sep 1, 2007 | 10:29 AM
4DR's Avatar
4DR
Good Numbers. But how is it stated that your 1200cc injectors and pump were maxed out/maxing out?? I would think those injectors would be enough to out-do your turbo.
Old Sep 1, 2007 | 10:31 AM
scorke's Avatar
Ethanol requires a lot more fuel to be burned to run at safe A/F's...E90 has less gasoline in it than E85 which requires about 30 percent more fuel.
On C16 30+ psi and 500+whp is probably attainable.
Scorke
Old Sep 1, 2007 | 10:40 AM
Lucas English's Avatar
I would say 5 pulls were due to dyno carp and the other 5-8 were Duggy getting his Greddy boost control dialed in so it would not bounce all over the place.
Old Sep 1, 2007 | 04:14 PM
SickSilverNLow's Avatar
Great job Duggy...... Your powerband looks very similar to mine ......bro...bro.....bro....bro...bro.......
Old Sep 2, 2007 | 07:00 AM
LayinLo's Avatar
Very nice!
Old Sep 2, 2007 | 07:14 AM
4DR's Avatar
4DR
Scorke
Thank you Sir. Understood.
