megan 02 gasket ix and vii
hey guys just realized something.. from what i can see the megan 02 housing is universal for the evo 8 and 9 correct? wouldn't the gaskets or designs need to be different as well due to 9.8 hotside compared to the 10.5?
Also, internally, the turbine wheels are identical as well. The main difference is the respective Area-to-Radius ratio(A/R) of the turbine housings. Externally, the 10.5 hsg. is noticeably larger than the 9.8, eventhough all mounting and gasket mating interfaces are held constant.
As a practical matter, you can swap a 9.8 HS onto a IX turbo with no problem and it'll line up perfectly with the stock O2 housing. So, overall compatibility should exist between the various aftermarket O2's and both the 9.8 and 10.5, 16G hotsides.
FS[West]: O2 housing, downpipe, QTP cat cutout
Drew1
Jun 17, 2016 11:46 AM
Sales@IveyTune
18
Oct 11, 2007 01:26 PM
andifidie
10
Nov 12, 2006 11:49 PM
