Tranny Sealant??
Old Sep 7, 2007 | 05:48 AM
AUSS1E's Avatar
Tranny Sealant??
So I am getting ready to do my clutch and the tranny is leaking slightly around the black inspection cover on the bottom. The manual says to use a Special PN sealant as it doesnt have a gasket.
Any other suggestions on what to use...>RTB, Gasket maker or just silicon???
TIA
Old Sep 7, 2007 | 08:31 AM
Luis@TTP's Avatar
you can use rtv silicone the gray one. that works just fine. is it leaking from the oem seal or through the inspection hole?
Old Sep 8, 2007 | 02:43 PM
AUSS1E's Avatar
yeah RTV is what i meant. I think it is the oem seal. I need to have a better look though. I know the torque on those bolts is only about 16ftlbs cause I already re-torqued them to make sure they werent lose.
Old Sep 8, 2007 | 09:47 PM
erioshi's Avatar
Use only Mitsubishi branded grey goo RTV .. I hear that when you order a tube the Borg CPU at Mitsubishi corporate issues you your own personal JDM part number...
Or not.
