losing boost?
Old Sep 7, 2007 | 10:15 PM
gen3eclipsegt's Avatar
losing boost?
right now i im tuned at 22.5 psi when i boost sometimes i hit 22 , mostley im hitting 17-19 psi i know the boost controller is working right cause i will hit 22 sometimes but im running stock bov on the evo 8 and startin to think its the bov and could be leaking is there a way i can test it or is that one of the reasons it could be doin that all my intercooler piping is on good as well
Old Sep 8, 2007 | 04:06 AM
sparky's Avatar
It could be a couple of things. If you are in 1st through third gears you may not achieve as high a boost level as you would in 4th or fifth, The stock turbo tends to peak and then taper down a couple of PSI. And yes the diverter valve or your boost controller could also be having an impact on this condition.
Old Sep 8, 2007 | 06:41 AM
alrite thanks alot man
Old Sep 8, 2007 | 06:42 AM
any recomendations on a bov for a injen upper and lower intercooler set up where the flange was i had a ssqv that i couldnt fit to recurculate.. i was looking at the agency bov
Old Sep 8, 2007 | 07:39 AM
krazirob's Avatar
i have not had any problems with my stock BOV as of yet. but AMS piping is my route with an HKS SSQV BOV.
Old Sep 8, 2007 | 07:41 AM
Warrtalon's Avatar
It has nothing to do with the BOV. You see different boost levels, because our boost hits different levels in different gears at different RPMs.
Krazirob, why in the world would you spend the money to downgrade your car by going from the JDM MR DV to the HKS SSQV?
Old Sep 8, 2007 | 07:42 AM
psphinx81's Avatar
no, go with the JDM MR BOV.. i had the HKS SSQV for awhile and after switching i found out how much of a piece of crap the HKS was.. go with the JDM MR BOV and ull be set
Old Sep 8, 2007 | 07:47 AM
Pure Playaer's Avatar
Just buy a used Evo9 BOV.. same thing n ull get it cheapr
Old Sep 8, 2007 | 08:18 AM
dose the evo 9 bov have the same mouting as the plastic pos evo 8 bov ... and how many pounds is that evo 9 good to
Old Sep 8, 2007 | 12:49 PM
RyuEvoIX's Avatar
It's good up to approximately 24psi.
PlanoEvo
E85 / Ethanol
11
Aug 19, 2010 09:21 AM
2plaz
Mar 19, 2009 07:44 PM
AUSS1E
10
Oct 15, 2007 09:25 AM
EvoJoeIX
Sep 23, 2007 11:34 PM
E VOL IX
May 2, 2006 04:32 PM
