Boost problems after reflash
Old Oct 12, 2007 | 06:48 PM
AUSS1E's Avatar
Not sure if it is related or not. But recently got reflashed after I upgraded my clutch and intercooler w/ piping.
The car is now low on boost most of the time. ie... around 13-14 psi. However.....Sometimes it will only go to that and hold it. Other times it will hit 10 and then climb slowly up to that. Still other times it will hit 21-22 and then fall back to 14. And then other times it will hit 21 and hold it good.
I am down to 2 things on what I think it could be. I havent done a leak test yet, and probably should but I would like to narrow it down.
I am thinking it is either my BOV (POS Greddy) or something on the reflash.
Am I pointed in the right direction>??? or anything else I should think about???
Old Oct 12, 2007 | 07:23 PM
Warrtalon's Avatar
If you have an MBC, then the ECU has no effect on boost - it's not even connected to the boost system.
Look at what else you changed when the problem occurred. There's only one thing that affects boost...
Old Oct 12, 2007 | 07:54 PM
cfdfireman1's Avatar
100% greddy pull it and look at the the diaphragm. good piece till it breaks. you can get a new diaphragm for about $70 they sell them for a reason.
Old Oct 13, 2007 | 03:22 PM
AUSS1E's Avatar
Thanks cfdfireman1....it was the BOV diaphragm. Its really shot....has a big tear in it.
You have managed to outdo warrtalon
LOL
Old Oct 13, 2007 | 04:16 PM
hoooo hooooo!!!!
LOL
I can die a happy man now.
Old Oct 13, 2007 | 05:47 PM
AUSS1E's Avatar
nice pic....mine was 10 times worse than that
I would get one and post it but I am a little too drunk celebrating UK over LSU right now.
Old Oct 14, 2007 | 06:19 AM
AUSS1E's Avatar
BTW I found it for $48.88 shipped on cardomainparts.
http://www.cardomain.com/shoplist~t~...ve+Accessories
Old Oct 14, 2007 | 10:34 AM
that's for the type r not the rs
Old Oct 15, 2007 | 02:22 AM
Ducu's Avatar
sorry im using this post 4 my problem !!!
2 days ago my boost spiked at 29psi and i can not do anything.
i adjusted my greedy ebc and still nothing... the boost goes like i have no limiter...
why?????
Old Oct 15, 2007 | 09:00 AM
Wastegate sticking perhaps?
Old Oct 15, 2007 | 09:25 AM
Ducu's Avatar
if i turn the ebc off it goes on mecanical boost 12psi... so it shouldnt be mecanical...
but the bad thing is i put oem solenoid, to go with my ecutek and itmakes 12psi...no more!!!!????!!!!
alfredoaal
18
Oct 26, 2015 01:43 PM
I eAt ChEeSe
Mar 10, 2009 07:01 AM
vikevo9
Mar 1, 2008 12:39 PM
Wangan_X
Mar 14, 2005 07:11 PM
johnnysixer
Dec 24, 2004 01:47 PM
