turbochargers.com TME Evo9 20G
http://www.turbochargers.com/store/p...products_id=63
has anyone tried out this turbo? how does it compare vs stock and the evo green
The Forced Perormance EvoGreen turbo(aka, Buschur Racing 20G-LT), is way superior to the Turbochargers.com 20G-TME-9.
Why? In the first place, the Forced Performance 5-blade compressor wheel is a more eficient design than the older 6-bladed design used in the turbochargers.com 20G. Furthermore, the Turbochargers.com 20G uses a small, high-backpressure 16G turbine wheel, whereas the hybrid Forced Performance 20G-LT is configured with a larger, low backpressure turbine wheel.
The Forced Performance turbo is about the same price as the unit you linked, but you get a lot more turbo for the money.
[It is a good turbo for the price. IT got me into the 11's @ a 118 on conservative 264/272 cams. The only downside is that it does not come alive until 26 PSI. There are better alternatives for a pump gas turbo. If you run an 03 with a 9.8 hotside it is a big step up.
confusionisbad
May 28, 2007 09:40 AM
midwestmonster
20
Mar 1, 2006 06:50 AM
