What psi to tune at
Old Sep 10, 2007 | 03:17 PM
bluebyu36's Avatar
who tuned him for 25 pounds????
Old Sep 10, 2007 | 03:18 PM
ballallday89's Avatar
Im not sure he just bought the car used. It has 28k miles on it too.... :/
Old Sep 10, 2007 | 04:02 PM
bluebyu36's Avatar
so how do u know he is tuned for 25 pounds????
Old Sep 10, 2007 | 04:07 PM
4WS Tuning's Avatar
you can have an aggresive tune even with 20 pounds, thats what you're not understanding... boost is only 1/2 of the battle....
if he has you very lean its just as dangerous as running too much boost.
Old Sep 10, 2007 | 04:13 PM
Marc Hatzi's Avatar
Very good Q.
Old Sep 10, 2007 | 04:20 PM
sharkm87's Avatar
yes exactly, myc ar was bought used too, and there was no boost gage in it, however there was a mbc in the car already...and hte maps were all f'ed, thx to mellon to fixing all that ..but car was boostin to high when i got it too....so i would suggest crankin that down, and not maxin out the boost until you get a tuner to pull the map and check it all out for you first......any gages in the car?
Old Sep 10, 2007 | 04:22 PM
Marc Hatzi's Avatar
You need Alky for 25. Or a upgraded IC...or both. Don't forget the head studs and fuel pump. Good lord I hope he has all of this.
Old Sep 10, 2007 | 04:33 PM
SlyEvo's Avatar
if his car is stock and running 25lbs it won't last for long...
Old Sep 10, 2007 | 05:20 PM
He has the dyno sheets and tunner sheets for proof.
Old Sep 10, 2007 | 06:36 PM
gsrboi80's Avatar
It can run 25 PSI all day with no knock stock as long as you pull enough timing out of the map.
Old Sep 10, 2007 | 08:11 PM
Robevo RS's Avatar
mine got tuned 25 psi without knocking,then got turned down to 23 psi for safety. So it is possible to run 25 psi without knocking.
But i do not like 25 psi on stock internal engine. It makes me feel more comfortable, if its 23 psi max.But maybe just me.
Old Sep 10, 2007 | 08:45 PM
[Advance]'s Avatar
What's he need it at 25psi for?
If it's a daily driver mind as well put it as low 20ish.
Old Sep 10, 2007 | 10:29 PM
Dead-Man Inc's Avatar
i have bolt ons and a base flash, and i left it at 1.4 BAR = 20 PSI .. waiting till i get a wideband, to be much safer.
this is on 91 oct btw
Old Sep 11, 2007 | 08:50 AM
bluebyu36's Avatar
i have a fully built block and i run 24 pounds on pump....
Old Sep 12, 2007 | 02:40 PM
bluebyu36's Avatar
well if he has the dyno sheets and tuner info, they you should know the answer to your question.......
