boost on evo!!! give feed back please.
Old Jul 6, 2003 | 07:03 PM
evoinit's Avatar
how much is a little to much boost on a stock evo
just put in turbo xs high performance boost controller and i don't want to go that high
Old Jul 6, 2003 | 07:08 PM
Fireball's Avatar
I wouldn't exceed 21psi without starting to worry. I believe 25-26 is max for that turbo and you may start breaking stock internals at that point.
Old Jul 7, 2003 | 03:29 PM
Shahul X's Avatar
plus I think its fairly ineffective after 21.5-22?
-shahul
Old Jul 7, 2003 | 03:36 PM
MalibuJack's Avatar
21psi is pretty much the max with good gas on a cool day.. on a real hot day I'd back it off a little just to reduce the risk of detonation..
Anything higher is just blowing hot air with a stock turbo and valve train..
Old Jul 7, 2003 | 07:09 PM
mitsuorder's Avatar
i know a friend that runs about a tad over 1.5 bar all day every day...
Old Jul 8, 2003 | 09:29 AM
ShapeGSX's Avatar
I wouldn't turn it over 19psi without a datalogger to make sure that the engine is not knocking. On race gas, turn it up higher.
Old Jul 8, 2003 | 12:11 PM
3deep's Avatar
Depends on the octane gas your running,if 91 keep it 19 or less psi.
Old Jul 8, 2003 | 12:58 PM
Speedlimit's Avatar
Admin Emeritus
You can make a lot of power with 19psi boost pressure. I guess the pre-occupation carries over from our DSM's. The 1G's came with 14psi or so and with proper supporting mods you could safely turn it up to 19 or 20 with a 16g on 93 octane pump gas. And that would yield great gains in HP. (plus fuel cut! ).
The EVO comes out of the box with most of the supporting mods and boost is probably the last thing you need to be tinkering with. The greatest gains are to be had from an AFC or piggy back of your choice and a small pressure drop exhaust. That combo will get you another 30 to 50hp. Add a set of HKS cams, throw in a timing map and you now have netted an additional 50 to 80hp. Most folks are going to be happy with 350bhp; at least I will and all on pump gas at 19psi.
Speedlimit...
Old Jul 9, 2003 | 08:38 AM
mikshan's Avatar
1.5 bar huh?So he is running abut 30 pounds of boost?Must be a methanol car built for indy racing.
Old Jul 9, 2003 | 07:24 PM
QuantumEVO's Avatar
Don't get too excited.
I used to run 1.4 bar on my heavily modified WRX with 93 octane all day long. This was with a large turbo and standalone, fuel pump, injectors, rails, lines, regulator, intercooler etc etc. 11.0:1.
I will say that 19 is enough until you are getting an intercooler, etc. Any more is not a good idea. It isn't effective. The turbo, however, will supposedly make power at higher boost levels with all the supporting mods. I have yet to see it myself, though. I run 20 max with IC and piping, fuel pump, engine management, intake, fuel press regulator, exhaust, etc.
Mark
www.quantum-racing.com
Old Jul 9, 2003 | 10:58 PM
mitsuorder's Avatar
Hey man just telling you what his Greddy electronic boost gauge reads at max ok
Old Jul 9, 2003 | 11:17 PM
evoVI_PR's Avatar
mikshan,
Sorry but 1.5 bar is not equal to 30psi. Its more like 21.76psi. I do believe the evo can stand that much. Caludius told me that with some supporting mods the evo could hold a max of 1.6bar, or 23.2psi.
Julian Gutierrez Jr.
Old Jul 4, 2004 | 11:09 PM
dangerous8's Avatar
So how much boost if you add
a larger intercooler, 780cc injectors, head studs, and fuel pump, along with lower ic piping? oh yeah, 272 in/ex cams too.
Old Jul 4, 2004 | 11:27 PM
gofaster87's Avatar
Just to let you know 1 bar = approx. 14.5 psi
