Leaking gear oil between trans & TC
I believe I have fluid leaking into the clutch area and the clutch is getting soaked with trans fluid
If i remove all my mods and take it in to be warrentied with they deny me if i got an aftermarket clutch?
i also had a exedy twin disk put in about 13k miles ago and it started leaking shortly after. when tech pulled the tc and tranny apart he found one of the o-rings smashed ! replaced it and now it is leaking again!!!!!
So your sure its a very simple problem? So just drop the trans and replace the o ring or install it properly?
What color is the fluid that leaks though? mine seems to be transmission fluid i believe and its black
I have the same situation after clutch install,but I checked the torque on the bolts (supposed to be 51 ft-lbs). Found a stripped bolt and I will need to drill and tap the tranny side. Not in a hurry to do the work yet, but in addition to checking the o-rings, I would recommend using a bead of sealant as well. Needless to say, I'll be doing all the work myself this time and not relying on others to create new problems for me
But could the bolts really cause the fluid leaking??I am about to try to fix this within the next few days..I have to think that It is leaking from around the output shaft of the trans because it is gear oil from the trans only that is leaking..I am REALLY not looking foward to doing this at all but my car has been sitting for almost 3 weeks now..
