Fuel Injectors?
Old Sep 18, 2007 | 06:15 PM
Celica2EVO's Avatar
Fuel Injectors?
Ok, here are the plans I have for my 03 EVO...please, no you dont need this or that, these are the things i have comep up with for my car! The thing I need to know, how big of fuel injectors would you suggest, and when would you put them in with these mods? Thank you for your help!
Stage 1
BR Filter Kit
Hallman Pro RX MBC
Walbro Fuel Pump w/kit
Stage 2
GSC S1 268 Cams
APR Head Studs
Stage 3
Weapon R Intake Manifold
Megan Header
10.5 mm Turbine Housing
02 housing
Buschur Racing 3” TBE bullet exhaust
Stage 4
Buschur Racing Race FMIC
Buschur Racing Race LICP
Buschur Racing UICP
Buschur Racing MAF Pipe
K&N Breather Filter
Buschur Racing Mini Battery Kit
HKS SS BOV
When Needed
ACT HD 6 Puck Clutch
ACT Prolite Flywheel
Old Sep 18, 2007 | 06:18 PM
kreionic's Avatar
you will be fine with the stock injectors. I have basically all the same mods minus the bov and things like that. Just different company and run fairly high boost. My idc% are in the low 90s
Old Sep 18, 2007 | 06:27 PM
BGevoIX's Avatar
Injectors
I have a IX and with intake, exhaust, intercooler piping, fuel pump and mbc set at 24 psi on pump, I was in the high 90% range for my IDC. I would suggest installing them around the time you install the cams, since they make a considerable difference in air flow, or with the intake and exhaust manifolds.
Old Sep 18, 2007 | 08:56 PM
Celica2EVO's Avatar
If I would decide to get them, what size do I need?
Old Sep 18, 2007 | 10:28 PM
TakaseEVOIXSE's Avatar
im also wondering when is a good time to upgrade injectors and what size....
Old Sep 18, 2007 | 10:39 PM
dubbleugly01's Avatar
on an Evo8, stock injectors are fine and are capable of matching all that the stock turbo will flow, regardless of other modifications. Looks like you have quite a few BR parts, what do they say?
Old Sep 19, 2007 | 01:52 AM
nasty8evo's Avatar
you should be good with the stock injectors
Old Sep 19, 2007 | 07:29 AM
Celica2EVO's Avatar
The only mods i have so far are the stage 1 mods, I only have the BR Filter kit as of now, and Im going to Buschurs on Friday to talk to them. Just wanted some opinions on the injectors. Thanks for your help, glad I dont really need to spend another $300 that I was looking at since I dont need them!
