firewall plugs issue
damn well this is confusing cause both the plugs will plug into that fuel pump relay. one is green and one is white lol. obviously you guys said the white one plugs into the relay so for the green ;/
The black green plug goes to the resistor you are pointing at. The black white plug connects to the relay in the picture. The gray white plug connects to the relay not pictured. The fourth plug connects to the resister below the relay pictured.
'what is this lol?' arrow is where the blk/grn plug connects to the resistor.
.edit. Do you mean a close up of the relay?
No i know what the relay is, so relay is white/black, and the resistor next to it is green and black?........ if so ill have to dig around to see if i can find that.
