Water/Meth Injection, FINALLY installed
Old Sep 20, 2007 | 11:55 PM
CrimsonShadow's Avatar
I know for most people this is not a major thing but for me, living in Phoenix, this is going to make a huge difference in the summer months. Rarely do I post pictures of installs but I have been waiting to purchase, install and tune this for so long that I wanted to share. The kit is from Be Cooling and is of excellent quality.
Trunk Mounted Pump tapped into washer reservoir
Switch Panel and solenoid Activation LED
Nozzle tapped into the upper intercooler hard pipe.
And my favorite part, when the airbox/scoop is installed the whole thing is invisible.
Old Sep 21, 2007 | 07:06 AM
deadbeatrec's Avatar
could the pump be installed any messier?
Old Sep 21, 2007 | 08:29 AM
Goodi32's Avatar
How much fluid does the washer reservoir hold and how often do you have to refill it?
Old Sep 21, 2007 | 08:36 AM
tweakdsm's Avatar
I found something, I might be wrong,
1) your nozzle is too far from TB.
2) your pump should be lower than your reserv for better flow.
bigric09's Avatar
i dont think so lol
Old Sep 21, 2007 | 08:42 AM
DsmAwdTurbo's Avatar
+1 The closer to the TB the better but I think it will work where its at.
The pump however should be lower thatn your res for better flow. I dont know what pump you have there but if its a 150 psi pump then keep an eye on your meth levels. The reason for the pump being lower is for a gravity feed. Constantly having water/meth in the line.
Old Sep 21, 2007 | 08:44 AM
tweakdsm's Avatar
^^^ nod
Old Sep 21, 2007 | 11:04 AM
Wow, you guys are just as harsh as I remember. That first pic of the pump was from the day I wired it so it wasn't 100% done but if looking pretty was my goal then I suppose I would have carpet in my trunk.
I really wanted to have the nozzle closer to the TB but the upper intercooler hard pipe I wanted is months away and I did not feel comfortable tapping the flexy pipe closer to the TB.
I don't know how much it uses yet because I need to mark the tank and figure out the mileage. As far as mounting the pump lower, it really wouldn't make a difference unless I tapped into the reservoir at a much higher point.
