only one cam???
Old Sep 22, 2007 | 05:58 AM
silverMRIX's Avatar
only one cam???
im new to the forum and i own a 06 Evolution IX MR i have 380 whp and the tune is custom done by mzm and i had a question i just bought the tomei log turbo manifold because i blew up the JIC tubular manifold. Now when i went to order the cam gears from tomei they said that i only needed the exhaust side cam gear because the car has mivec. now the question i had for you evo gurus is this true do i only need one of the cam gears???
Old Sep 22, 2007 | 06:18 AM
skold's Avatar
yes, mivec is valve timing that is always adjusting, so if you put on a cam gear and adjust it you will break your valves. im a tech at lexus and we had a kid up aem cam gears from a supra on his is300 well lexus has VVTI varible valve timing with intellagence, and he ended up having ot buy a new motor.
Old Sep 22, 2007 | 09:10 AM
xxNosTankxx's Avatar
This is something I'm interested in as well.
So the Mivec only has one cam and cam gear??
Old Sep 22, 2007 | 12:11 PM
nikkadanny's Avatar
evo's have 2 cam gears and 2 cams but you can only purchase the exhaust cam gear and you have to order the evo 9 mivec cams
Old Sep 22, 2007 | 01:11 PM
EvilTechnology's Avatar
Is it even needed/recommended to change the cam gear on a IX? I thought not.
Old Sep 22, 2007 | 02:51 PM
nikkadanny's Avatar
i dont really know anyone that has changed out a cam gear on a ix, i seen one person on here that has
Old Nov 18, 2007 | 07:52 PM
hmsevo9mr's Avatar
I did.
Old Nov 18, 2007 | 08:03 PM
iturregui's Avatar
That must have hurt
