boosting problem HELP
Old Sep 22, 2007 | 02:56 PM
gen3eclipsegt's Avatar
Question boosting problem HELP
right now im tuned at 22.5 psi i keep hitting 15- 18 psi sometimes when i creat boost it will be 15 sometimes it wlll be 18 i changed the bov to a greddy rs and its more to the hard side and i tried turning up the boost controller and it dosnt do anything i did about a full turn and still read the same boost... eariler today on the way to work went to boost and hit 21 went to boost again 15psi
Old Sep 22, 2007 | 07:42 PM
sparky's Avatar
You might try switching back to the stock DV, in place of the aftermarket BOV, just for comparison's sake.
Old Sep 22, 2007 | 07:54 PM
FedEvo8's Avatar
You may want to do a boost leak test.
Old Sep 22, 2007 | 08:38 PM
sparky's Avatar
FedEvo8: Are you running larger injectors? Or, are you still on the stock nozzles? Sorry for the OT.
Old Sep 22, 2007 | 09:34 PM
stock injectors i dunno what the problem is i was thinkin maybe wastegate?
Old Sep 23, 2007 | 06:26 AM
sparky's Avatar
Off the cuff, I'd guess that your problem is either WGA related(insufficient tension & actuator rod needs shortening), a boost leak(do a leak test), MBC related(incorrect vacuum line routing, or loose, leaky vacuum hose), or your BOV(go back to the stock DV just to see if that cures the problem). You should be able to track this down. Let us know.
Old Sep 23, 2007 | 08:00 AM
sounds good man will do thanks alot ill keep updated
