New Dyno #'s
Old Sep 24, 2007 | 04:14 PM
silver evo8's Avatar
New Dyno #'s
i just went to dynoflash last weekend and got a custom tune from Al
with all of the mods below i made 334whp & 308tq at around 22psi and it pulled all the way to redline due to the 18psi wastegate, i am satisfied for now but cams, studs, clutch, and meth are coming in the spring or i might just forget about the meth and go for a 3076r if i have enough money
im going to post up pics soon for the first time
Old Sep 24, 2007 | 04:23 PM
bluebanana23's Avatar
check for a boost leak since your tq. is that much lower than your hp.
Old Sep 24, 2007 | 04:48 PM
i checked before i got it tuned for a leak and i didnt find anything but ill check again and should my tq and hp be closer together
Old Sep 25, 2007 | 04:56 AM
anybody?
Old Sep 25, 2007 | 05:14 AM
TeStUdO's Avatar
Those numbers look fine. You just arent running alot of timing at spoolup. If you posted your graph your torque is probably pretty flat. Decent #'s with no cams.
Old Sep 25, 2007 | 07:03 AM
mac74's Avatar
Very good numbers. Do the cams studs and meth and watch it go over 400whp..
