E-manage Base maps
Old Jul 8, 2003 | 01:51 PM
AustinEvo8's Avatar
Question E-manage Base maps
Do you know where I can find base maps for the Evo 8 on E-manage. I just installed the emanage, ignition, and injector harness, but need to plug in base maps to get it safely to an AWD 200+ miles away.
Looked throught the forum and at the trust-power.com site, but can't find anything.
Old Jul 8, 2003 | 01:55 PM
YellwTyper's Avatar
You should be ok with stock settings. Its bascially not adjusting anything until you tell it to do something, but until then it should be in stock map form.
Old Jul 8, 2003 | 06:46 PM
992gnt's Avatar
The stock maps default is zero percent correction. As long as you didn't put any numbers in the maps or adjust the AAV dials, the e-manage is doing nothing to your car.
