Evo 8 Mr Vs Evo 9 Turbo?????
Old Sep 26, 2007 | 11:31 PM
Boost3dxEvO's Avatar
Okay so I have an 8 MR. 16g w/10.5 hotside... I also just bought a setup that has a 9 turbo on it. 16g w/10.5 hotside.
My question is... with the 9 turbo having a bigger compressor housing.. does this achieve more HP??
I just need to know if putting on the evo 9 turbo is going to give me better numbers than my 8 w/10.5 hotside??
Is the Ix's power based off of the turbo or is it just the MIVEC?
PLEASE HELP ME!!!!
Old Sep 26, 2007 | 11:36 PM
tripperfx3's Avatar
Id honestly have to say mostly MIVEC, but after riding in an 05 VIII with the 10.5 and a friends Evo IX (all with the same mods. The VIII actually has an upgraded FMIC and the IX doesnt) the IX was smoother and faster hands down and the turbo on the IX just felt better. Cant really explain it, but the IX turbo should make more power over the VIII turbo.
Old Sep 27, 2007 | 05:33 AM
sparky's Avatar
Originally Posted by Boost3dxEvO
Okay so I have an 8 MR. 16g w/10.5 hotside... I also just bought a setup that has a 9 turbo on it. 16g w/10.5 hotside.My question is... with the 9 turbo having a bigger compressor housing.. does this achieve more HP?? I just need to know if putting on the evo 9 turbo is going to give me better numbers than my 8 w/10.5 hotside?? Is the Ix's power based off of the turbo or is it just the MIVEC?PLEASE HELP ME!!!!
The IX turbo for the win! The IX turbo has a more efficient compressor housing design than the VIII turbo does. The topend flow should be better, resulting in a potential 10-15 WHP difference. Go for it!
Old Sep 27, 2007 | 07:25 AM
thanks SO much for the replies.. any one else???
Old Sep 27, 2007 | 07:36 AM
Dead-Man Inc's Avatar
u'll find some gain with the IX turbo. OR !! .. just send out the IX turbo to buschur and swap it to an 20G - LT
Old Sep 27, 2007 | 08:58 AM
scheides's Avatar
EvoM Moderator
Yup, 10-20whp gains over the VIII turbo w/ 10.5 hotside, so you'll be happy just swapping that in. Upgrade it to an evo green for more significant gains, but just swapping in the IX turbo is a nice way to make a little more power.
Old Sep 27, 2007 | 10:29 AM
shivaswrath's Avatar
remember with the FP to add injectors (min 750cc, right?) and a good tune + 9 installation kit (revised lines since the compressor housing is bigger). . .I'm holding out on adding the FP green. . .and hoping it'll add 40awtq at 24psi!!
Old Sep 27, 2007 | 10:32 AM
Jeff_Jeske's Avatar
I did the swap on my eight and it was worth it. Stronger mid range and it could hold more boost up top. Spool was about the same. If you put the 9 snail on an 8 you will need the 9 outlet pipe too. Also recommended to add the tubular O2 housing at the same time.
Old Sep 27, 2007 | 10:39 AM
svtkiller's Avatar
Here you do the math.
Old Sep 27, 2007 | 10:44 AM
Cali2MDevo8's Avatar
Registered User
PLEASE HELP ME!!!!
Where have you been buddy. This is common knowledge. Just look at the picture. While you have the 9 turbo unbolted, I would send it in for the FP evo Green turbo.
jason
Old Sep 27, 2007 | 10:56 AM
RyuEvoIX's Avatar
Old Sep 27, 2007 | 11:24 AM
tripperfx3's Avatar
DAMN!!! I knew it was bigger, but ive never seem them compared side by side!
Old Sep 27, 2007 | 11:31 AM
scheides's Avatar
EvoM Moderator
Isn't the one on the right the evo green? Note the 5-blade compressor wheel...
Old Sep 27, 2007 | 11:44 AM
mplspilot's Avatar
^ Nice catch. It is a green. Nice post, svtkiller...
Old Sep 27, 2007 | 09:48 PM
EVIL_EVO_VIII's Avatar
The IX turbo should be 15-20whp over the VIII turbo.. Do a search, theres dyno sheets somewhere on the forum
