gauges!!
Old Jul 8, 2003 | 08:03 PM
evoinit's Avatar
gauges!!
hey what do you think are the most accurate gauges
just got the autometer carbon series boost gauge
cause anything is better ten stock
Old Jul 8, 2003 | 08:09 PM
stvbreal's Avatar
I got the Sport Comp series and they work fine for me. Boost, A/F and EGT.
Old Jul 8, 2003 | 08:39 PM
silverEVO8's Avatar
Where did you hook up your EGT? I'm undecided between the header before the turbo and the down pipe after the turbo... Oh yeah, what readings are you getting?
Thanks
Old Jul 8, 2003 | 08:48 PM
leousm's Avatar
"Sorry officer I don't know how fast I was going because my gauges were blocking my speedometer!"
Just messing with ya, but seriously how's the visibility of the instrument cluster?
Old Jul 8, 2003 | 08:52 PM
stvbreal's Avatar
I should have mentioned that the EGT is not hooked up yet. I too am waiting to drill for the probe. I am drilling into the first runner, on the header. I have been told this is the most acurate spot.
From the picture it looks like it would obstruct the view of the stock cluster but it doesn't. well it does, but it doesn't. The boost and the A/F gaguges sit in the middle of the MPH and RPM on the stock cluster. You can see the tip of the needle as it moves up MPH and RPM and around the outside of the Boost and A/F gauges. Does that make any sense?
Anyways, visiblity is good.
Old Jul 9, 2003 | 07:26 AM
silverEVO8's Avatar
I thought about the gauge placement quite a bit. I don't like to put them in front of the instrument panel so I'm working on a 2 position gauge pod to go in the stock HU location. I'm relocating my HU to the cubby hole location. You all might be intersed in this option. I've got another thread on the subject, but I'll ad a picture anyway.
Old Jul 9, 2003 | 03:39 PM
JeffWels's Avatar
where did you get the pods from and how did you mount them to the steering colomn?
Jeff
Old Jul 9, 2003 | 03:49 PM
stvbreal's Avatar
Jeff
Got the gauges from a local Import shop. I think they got them from Jegs Also the gague pods I think came from Jegs. Drilled holes in the steering column cover and screwed them in. That cover is hard material so it won't strip the screws if you are careful. And they don't move or wiggle around, they are solid.
Old Jul 9, 2003 | 08:29 PM
ADMstunna's Avatar
stv, how do you see the tach? or speed? or fuel?
Old Jul 9, 2003 | 08:33 PM
SilverEvo8owner's Avatar
hey stv
where in columbus is this import shop
Old Jul 9, 2003 | 08:36 PM
stvbreal's Avatar
Advanced Imports. They hipped me to it. They hooked me up with the boost controller and install, the rest of the mods I did myself. I started with 1 Defi boost gauge. Ended up with 3 autometer. Don't ask.
Old Jul 9, 2003 | 08:37 PM
where is it?
Old Jul 9, 2003 | 08:40 PM
stvbreal's Avatar
As I said above I can see them fine. The boost gauge is centered witht the MPH, the A/F is centered with the RPM and the fuel is just to the left of the EGT. The picture was taken lower than I would sit. The only thing that I can't see is the gay Lancer gauge, whatever that's for, which is fine with me
Old Jul 9, 2003 | 08:42 PM
stvbreal's Avatar
Originally posted by SilverEvo8owner
where is it?
They are right off Roberts road, on the other side of 270. They mainly work on RX-7s but they know turbos.
Old Jul 9, 2003 | 08:43 PM
is that in hilliard?
