Um yeah 2step not working
Old Sep 29, 2007 | 03:05 PM
kaonashi's Avatar
I think it might be a sensor unpluged. i found under my dash a plug that has like 1 wire on it maybe 2.
But anyways, i tried to test the 2step because i wass just wondering what its set at and little to my suprise it went way past 6k so i backed off i was expecting it to hit at 5.5k where jestr set it.
and it was in first gear, and the clutch was pushed down as far as it could go. could the Ebrake have anything to do with it?
Old Sep 29, 2007 | 03:27 PM
kaonashi's Avatar
sigh im sure someone knows how to get this thing working.
Old Sep 29, 2007 | 03:47 PM
Warrtalon's Avatar
There is a white plug near the top of the clutch pedal that must be connected for the 2-step to engage.
Why 2 threads in 2 separate forums?
Old Oct 2, 2007 | 09:58 PM
MSFIT's Avatar
mine doesnt work either
I have an 05 GSR
when I got tuned they checked it out real quick, they said it was on, he reset it to like 4000 instead of 5500 still doesnt work
the nuetral safety switch is operational.
I'm thinking maybe a screwed up speed sensor? car thinks im not at 0mph
the previous owner said it just went away.
Old Oct 3, 2007 | 12:43 AM
Asmodeus6's Avatar
I have an 05 GSR
Slightly OT, but let me tell you from one 05 to another. And I don't know you're mods but I have a few & a tune. Set the SB back to 5000. You might as well not even set the car on the SB @ 4k. It will bog very... very bad. Mine was @ 4, and the car fell flat on its face.
I set it to 5k, barely slipped it and went 1.8 60ft 12.61 @110.
4k SB had me in the 13's from such a shi**y bog. Its pointless.
If you're on the stock clutch you'll have to really slip it out from 4k. And it will cook it. Luckily I had ecuflash & my laptop @ the track to fix it.
I've changed my own SB several times and its worked every single time.
GL fella's.
Old Oct 3, 2007 | 12:56 AM
moreryce's Avatar
ebrake doesnt let it work.. make sure the car is completely still...
Old Oct 3, 2007 | 04:09 PM
20psiMR's Avatar
+10000
I set my ebrake most of the time to get it started, then drop it and go a few secs later. If the car is rolling even an inch the 2 step disengages.
Old Oct 18, 2007 | 01:54 PM
kaonashi's Avatar
I want to put this out to everyone, My 2step works with Ebrake up and in neutral.
Old Oct 18, 2007 | 01:57 PM
TouringBubble's Avatar
That's odd ... sounds like something is up with whatever sensor lets the ECU know that the car is in gear.
Old Oct 18, 2007 | 02:03 PM
kaonashi's Avatar
lol that but my buddies does the same thing aswell. our Shell's are 03's so i dunno if that has something to do with it.
