Good Clutch?
Old Sep 29, 2007 | 04:36 PM
bhamEVOguy's Avatar
Good Clutch?
i have an 03 EVO VIII with 47,300 miles on it and yesterday the clutch started slipping. the reason i think its slipping is because flooring the gas @ bout 2500 RPMs, it hesitates. it shows its getting full boost but its not pulling as hard and sometimes it would just slip around 4000rpms then grab again around 5000rpms. that was in 4th gear. when m in 5th gear, as soon as i hit full boost, the rpms would just climb to 6-7000.
but what i dont understand is that its only doing this in 4 & 5th gears. 1,2,3 pulls hard.
if it is my clutch, what is a good clutch for street use i can buy without spending a lot of money. m kinda tight on cash rite now.
Oh and yes i did search but was still a little confused
These are the mods:
3"TBE
Nisie LICP
XSPower FMIC
Cone Air Filter
Hallman MBC set to 23PSI
Jester Tune
thanx in advance.
Old Sep 29, 2007 | 09:45 PM
bhamEVOguy's Avatar
anyone???
Old Sep 30, 2007 | 10:00 AM
bhamEVOguy's Avatar
Bump for some info!
Old Sep 30, 2007 | 10:06 AM
Evolution MR IX's Avatar
exedy twin hd. thats what im getting. good enough is not good enough. get the best.
Old Sep 30, 2007 | 10:10 AM
beemerfreak's Avatar
ACT HDSS
I have it sitting in my room. I hear its the best clutch for the money ($485) and its not a pain to daily drive. It also holds up to 475+ WTQ. That means you can launch and not worry about it slipping like the stock clutch.
Old Sep 30, 2007 | 10:11 AM
dodgecoltracer's Avatar
ACT HDSS is cheap, most people recomend the exedy twin...
use the search feature, it works wonders... here are some relating to daily drivers ===>
https://www.evolutionm.net/forums/se...archid=6333686
Old Sep 30, 2007 | 10:26 AM
xxNosTankxx's Avatar
im going with an RPS 6 puck...
Old Sep 30, 2007 | 10:35 AM
homiusang's Avatar
The load is higher when you accelerating in higher gears, thus the tendency of more slippage. Just like when you floor it in higher gear, the car tends to boost a little higher than lower gears, because of higher load.
Old Sep 30, 2007 | 11:00 AM
EvoInvidia's Avatar
remember to get a light weight flywheel too. But for the money I'd go with the Act heavy duty with the street disk, HDSS-MB17 I believe is the part number for the clutch set.
Old Sep 30, 2007 | 09:18 PM
bhamEVOguy's Avatar
looks like i'll be getting the ACT clutch kit.
do i really need to get a flywheel or could i just resurface the stock flywheel?
Old Sep 30, 2007 | 09:25 PM
If your flywheel is in good condition just get it resurfaced. If its to beat up and you cant resurface it, you can find a used stock flywheel in the for sale section for less than $100 if you need to.
Old Oct 1, 2007 | 02:15 PM
bhamEVOguy's Avatar
Just ordered the ACT HDSS. should be here this weekend. hopefully i can just re-use the stock flywheel.
thanx for the help guys
Old Oct 2, 2007 | 07:57 AM
Solo II Evo's Avatar
good luck man, let me know how that clutch works out for you.
Old Oct 2, 2007 | 08:04 AM
deadbeatrec's Avatar
for what?????? u have 300whp and 300tq, do u just want to look like u dont know how to drive your car or something?
my vote is the ACT HDSS. i have it and i have 472whp and 426tq. it holds so far like a champ
Old Oct 2, 2007 | 08:43 PM
What does HDSS stand for? Damn I hate being a newbie.. is it the Xtreme duty? Can you link me to the clutch you're talking about?
Where did you guys order it from?
Thanks...
