why do my plugs look like this????
i was getting a missfire on cylinder 1 so i cleared the code and checked my plugs and 1/3 cylinders have this white s***t and rust on them ?????? they are ngk irid's i am going to replace them but what is up with them??
cylinder 2 and 3 looked brand new???
Looks like 1 and 4 had salt-water setting in there without use and corroded them.
Alot of my tranny bolts looked like that whan I changed my clutch. I figured after manufacture my car sat on the ship port collecting corrosive salt air before it was shipped by truck.
I don't think that the BP8ES's are widely recommeded on here for the Evo VIII's. Probably for a fairly stock DD, either the NGK BPR7ES or the NGK BR7ES, would be a better bet, IMO. Gap them at .026". Torque them to 17-19 ft/lbs.
do a compression test bro!
the last time i had a misfire we did a compression test and then we find out that my cylinder 4 was low compression 140psi and the rest were 160's . I just ignore it then after a month KABOOOOM!!!! There you go bent/ stretched the rod bolts of the cylinder 4. It happen in a low speed below 3k rpm 2nd gear.
Do a compression check!!! if you find a low compression.....drain the oil and pull your oil pan and check your rod bolts and internals...
