Looking to get green turbo
Old Oct 1, 2007 | 11:29 PM
  #46
APEX1's Avatar
gimmie a freakin break man! c-mon!
Old Oct 1, 2007 | 11:35 PM
  #47
elhalisf's Avatar
Originally Posted by sparky
Forced Perormance can use the center housing as well as the turbine housing from your VIII turbo in building an EvoGreen. They would, however, need to supply you with a IX compressor housing, milled out for the Green's larger compressor wheel.
As far as the turbine housing goes, either of the two USDM spec VIII turbine housings can be used in building your Green. So yes, they can build you a Green turbo, using your existing stock VIII turbo as a starting point. Call them.
you are incorrect. the compressor housing AND the center catridge of the IX is larger than the VIII. no part of that "cold side" is swappable into the green. however, stock IX and VIII turbos share the same compressor and exhaust wheel.
Old Oct 1, 2007 | 11:36 PM
  #48
04AWDTURBOEVO's Avatar
Originally Posted by APEX1
lol
nope!! not if I shift at 65 or 67 which my tuner told me 2 if im racing. look when your tq hits than mine? look when your whp hits than mine. lol its not enoughto beat the cars I listed. and like I said not maore than a car on me.
No problem, sir. You take it easy out there.
Tell your tuner 'The King of the Streetz' says Hi, .
Old Oct 1, 2007 | 11:40 PM
  #49
APEX1's Avatar
if you think you king of the street with a green than your for sure not a dumbass.
Old Oct 1, 2007 | 11:45 PM
  #50
sparky's Avatar
Originally Posted by elhalisf
you are incorrect.....the center catridge...
I never mentioned a "center cartridge". At least, I don't recall having mentioned such a thing. Of course, I've had a few
Old Oct 1, 2007 | 11:48 PM
  #51
sparky's Avatar
You are refering to firearms right? You mean a centefire cartridge, as opposed to rimire. This is a joke, right?
Old Oct 2, 2007 | 12:04 AM
  #52
Qatar_Evo's Avatar
Wow all of that start bcoz of me LoL
Old Oct 2, 2007 | 12:10 AM
  #53
elhalisf's Avatar
ok, so you reffered to it as the CHRA as the entire assembly. it is sometimes reffered to as the center cartridge. the IX CHRA is not the same as the VIII CHRA.
Old Oct 2, 2007 | 12:13 AM
  #54
sparky's Avatar
I agree with you that the IX compressor housing is larger than the VIII compressor housing.
I also agree with you that neither the VIII compressor housing, nor the 16G compressor wheel are used on the EvoGreen in its current iteration. If I'm not mistaken though, I think that FP did for a while convert customers' VIII 16G's ito EvoGreens.
As a practical matter it is physically possible to machine the VIII compressor housing to accept the FP 69 mm compressor wheel. There are a few of these running around.
Just to set my mind straight...When you say that the center cartridge is larger, what exactly do you mean? Large, compared to what?
The cast center housing on all 16G's(and the Green) is identical, AFAIK.
Old Oct 2, 2007 | 12:19 AM
  #55
elhalisf's Avatar
yes FP did convert VIII turbo's, but they are now facing a shortage of IX compressor housings. That is why they are only doing the IX conversion.
the physical dimensions of the center cartidge is larger, ie, the outer radius. the CHRA inserts into the compressor housing, so when you have larger compressor housing, you must have a large diameter CHRA. i have rebuilt the VIII and IX turbo's and i have seen the difference first hand.
Old Oct 2, 2007 | 12:34 AM
  #56
sparky's Avatar
Do you realize that our discourse is divergent. The turbocharger is composed of three cast iron housings: 1) Compressor housing, 2) turbine housing, and, 3) center housing.
I apologize for the misunderstanding. The CHRA(center housing rotating assembly) includes the cast iron center housing as well as the rotating assembly, which is composed of the shaft and the two wheels, and I think the term includes the bearing assembly and seals as well.
I'm too lazy to Google the term center cartridge in the Garrett Glossary.But, what you refer to as cartridge does in fact exist and is distinguished from the more inclusive term, CHRA. The cartridge, is I think, part of the CHRA. I think now that cartridge is the two wheels mounted on the shaft as an assembly.
Old Oct 2, 2007 | 12:40 AM
  #57
elhalisf's Avatar
maybe i have my terminology wrong. i was reffering to the cartridge as the cast peice were all the bearings, wheels and shafts mount inside it. the CHRA is the entire assembly together.
although, all the inner components of the CHRA are the same between the 2 turbos, the outer cast peice/shell is not.
Old Oct 2, 2007 | 12:49 AM
  #58
sparky's Avatar
Wink
yes FP did convert VIII turbo's, but they are now facing a shortage of IX compressor housings. That is why they are only doing the IX conversion. the physical dimensions of the center cartidge is larger, ie, the outer radius. the CHRA inserts into the compressor housing, so when you have larger compressor housing, you must have a large diameter CHRA. i have rebuilt the VIII and IX turbo's and i have seen the difference first hand.
I really don't have a beef with you. I just don't think that you know what you are talking about. If you can rebuild turbos, then so can Fred Flintstone! I'll bet you can't even change the tires on my kid sister's Barbie Beach Buggy.
Old Oct 2, 2007 | 12:52 AM
  #59
elhalisf's Avatar
who said anyone had beef with anyone. i was simply having a discussion.
and no, i really wouldn't know how to change the tires on your kid sister's Barbie Beach Buggy
Old Oct 2, 2007 | 05:18 AM
  #60
Cali2MDevo8's Avatar
Registered User
Originally Posted by 04AWDTURBOEVO
I have raced other Evos with more HP than you. 4-6 cars to 170+, .
Take a look at my numbers in the graph, my car makes 110 more whp than yours at 7,500 rpms:
That is enough to walk you all over, and leave you in the dust, .
Yours:
https://www.evolutionm.net/forums/at...7&d=1189563127
Thos are great numbers at 7000Rpm. Something I look forward to in the next few months. What are your supporting mods?
Jason
