turbo upgrade
turbo upgrade
hey guys i have a evo IX with intake,dp,cutout, hks cams, fuel pump, boost controller on 23 psi it made 357whp and 371 ftlbs of torque i wanna what turbo i can put in that will put me in the 450hp range besides the obvious like a gt35 kit and what not.... any help is appericated
FP Green with full bolt ons and high boost will make ~450whp on Dyno Jet.
My goal for the green is 400/400 on a Dyno Dynamics. These will hopefully get me there @ 25psi:
Helix 3" Downpipe
Helix 3" Test Pipe
Helix 3" Cat-Back Exhaust
Walbro 255 Fuel Pump
AGP 24x12x3.5 Front Mount Intercooler
Nisei Black Lower Intercooler Pipe
ETS Black Intake w/ K&N Filter
Precision 780cc Injectors
Cosworth IX MIVEC Cams
ETS Black Upper Intercooler Pipe
Okada Plasma Direct Coil Packs
eBay 02 Housing
Ported Stock Exhaust Manifold
Ported Stock Turbine Housing
Ported Stock Intake Manifold
65mm Ported Stock Throttle Body
Forge High Boost Wastegate Actuator
Forced Performance 20G Evo Green Turbocharger
Helix 3" Downpipe
Helix 3" Test Pipe
eBay 02 Housing
go with the ams 3076 or if u want more power buschur makes a nice kit with the 3065 which is almost like the 35r...i think u should stay away from the 50 trim...i dont think its gonna give u that much power to be in the 450 hp range witout meth or alcky....instead of the 50 trim go with fpgreen turbo its real cheap to
yea if your considering a 50 trim i would just get a green. the green has already proven itself against the 50...but if you wanna get something a lil bigger the buschur 3065 would be your best bet since it makes about the same power as a 35r up to 30psi and since your just on 93 it looks like the best turbo to get since it has much room for more power if you wanna run meth or race gas in the future
