What Do I Need For A Clutch Install?
Old Oct 2, 2007 | 12:40 PM
beemerfreak's Avatar
I've got the clutch, TOB, alignment tool, SS clutch line, and we are going to resurface the stock flywheel. My cousin owns a shop and his mechanic is going to do it for me.
Do I need any oils for the ACD and where can I get it from? We have to drain the ACD fluid right?
Old Oct 2, 2007 | 12:50 PM
Charlie_B's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=274987 (pics dont seem to work anymore)
https://www.evolutionm.net/forums/sh...ad.php?t=91901
http://evomoto.com/tech_info.php?tec...43640ffc8bc54c
Couple things come to mind real quick. More than enough jack stands and jacks, a buddy or two that owes you a big favor, lots of beer, and a TON of patience.
Good luck
bump!
Markley02's Avatar
No you do not need to drain the ACD. I didn't. Leave the banjo bolt attached and just pull the ACD out of the way. Dont totally disconnect it.
You will need some diaqueen LSD fluid for the transfer case and some trans fluid (I used redline MTL and MT-90)
