Boost leak test need help??
Old Oct 2, 2007 | 03:13 PM
jrsimon27's Avatar
iam rigth know doing a boost leak test to my car and when the boost gauge hits 1.0bar=14.7psi air starts to leak from the oil filler cap on the valve cover , i dont understand this cause i dont have any oil leaking from it,what could it be is this normal?
thanks
Old Oct 2, 2007 | 03:32 PM
jrsimon27's Avatar
bump
Old Oct 2, 2007 | 05:14 PM
Luis@TTP's Avatar
No, its not normal I would look into the ruber seal under the oil filler cap then try it again.
Old Oct 2, 2007 | 06:11 PM
jrsimon27's Avatar
i found the problem
i hooked up my homemade pressure tool on the maf pipe and not on the turbo itself so the maf pipe has a hose that goes directly into the valvecover so i unhooked this hose used a bolt to prevent air coming out of it and that was it the boost gauge went to 22psi with no problem and to my surprise i found 3 boost leaks they were practically invisible i would have never ever known this leaks where there i highly recommend a boost leak to every one my car has 20,000miles on it.
thanks
Old Oct 2, 2007 | 07:27 PM
jrsimon27's Avatar
here are some picks i took while doing the boost leak test
Old Oct 2, 2007 | 07:32 PM
Evoryder's Avatar
goodfix
Old Nov 18, 2007 | 05:04 PM
macevo8's Avatar
I think this brings up another question though. How much pressure should the oil cap be able to hold? and does it even matter? I did my boost leak test today, had the tester hooked up to the maf pipe and fixed a few bad leaks. Once they were all good I noticed the oil cap would leak at around 15 psi just like the OP. I know there are lines that go into the valve cover but I purposely tested from the maf pipe and left all lines connected so that I could pressure check the entire system. I just wanted to check with evom before I bought a new cap, and I came across this thread. Any inputs?
Old Nov 20, 2007 | 06:38 AM
krispytapa's Avatar
mine leaks @ .6 bar. i'm not sure if it's normal or not.
Old Nov 20, 2007 | 06:46 AM
mifesto's Avatar
Originally Posted by jrsimon27
i found the problem
thanks
where was ur 3 leaks?
Old Nov 20, 2007 | 08:48 AM
MR. Tim's Avatar
Doing a test this weekend. Would like to know where you found them also....
Old Nov 20, 2007 | 10:59 AM
Evoryder's Avatar
really doesn't matter where he found them...cars are different...you have different mods etc.
If you want common leaks then that's a different story. Couple off the top of the head..throttle body seal leak(20k+/high boost applications)/licp, injectors...etc
Get your dishwashing soap out and put in a spray bottle....
Old Nov 20, 2007 | 03:48 PM
jrsimon27's Avatar
i found them 2 on my licp and 1 one of them o the connections of my mbc
