Head Problem Please Help!!!!!!!
Old Oct 9, 2007 | 11:23 AM
scottatyamaha's Avatar
Originally Posted by sabastian458
That looks like they reused the spark plug, or you still have a chunck of something in the combustion chamber.
I agree have you put in a new plug since all of this happened? Like sabastian said it could be the old plug.
Old Oct 9, 2007 | 12:58 PM
CO_VR4's Avatar
Find a shop with a borescope, and you can find out quickly if there is anything in your cylinder without removing the head.
Old Oct 9, 2007 | 06:22 PM
C6C6CH3vo's Avatar
Something is in there banging around. See if your nozzle is still there. Best of luck
Old Oct 12, 2007 | 06:39 AM
Ricekiller81's Avatar
I change the plug out to a new one, but the problem continues.
Old Oct 12, 2007 | 06:45 AM
CO_VR4's Avatar
Insanity: doing the same thing over and over again and expecting different results.
Albert Einstein
Old Oct 12, 2007 | 07:07 AM
sparky's Avatar
What kind of plugs are those? Did you install new plugs or reuse the old plugs?
Old Nov 19, 2007 | 06:32 AM
Update: My friend and I pulled the head off to see if there was someting stuck on the valve or a somthing melted on the pistion. We found nothing. We even turned over the cams to expose the valves and didnt see anything either. We then put everthing back toghter and tapped the meth line to a new Nisei UICP and the car ran good unitl the damn spark plug became crushed once again. I did some other trouble shooting like changing plugs BPR8ES, coils and Injectors off my girls evo. The car ran awsome for like 10mile drive, but the problem happend again. The only thing I can think of is that there is something between the valve and valve guide that when the chamber get realy hot it get loose and starts to ping ponging aroung the chamber. Any help or Ideas guys would help me out alot at this point before I pull the head of again. Thanks
Old Nov 19, 2007 | 06:51 AM
chrisblueevo's Avatar
Albert Einstein
lol
Old Nov 19, 2007 | 07:02 AM
Bump for Help!
Old Nov 19, 2007 | 08:41 AM
C6C6CH3vo's Avatar
First of all right now, not before, is the plug getting smashed or nicked all over the place?
If it keeps getting smashed and doesn't appear like the original plug pics then you need to drop the sump and inspect the #1 rod bearing.
If plug does look like the original pic up there you need to get a strong vacuum and suck out whatever is in there (make sure the #1 isn't at compression stroke or you wont be able to suck it out)
Old Nov 19, 2007 | 09:46 AM
If it was a rod Bearing woulnt the out of my problem be worse. I also forgot to add that a sort of ticking sound is coming from the left side of the head very of beat form the rest of the head and lifters were bled.
Old Nov 19, 2007 | 11:50 AM
Bump for help
Old Nov 19, 2007 | 01:10 PM
C6C6CH3vo's Avatar
Well, you pulled the head off and nothing was in there. Have you checked compression again?
Have you tore open the oil filter?
Pulling the sump and inspecting the rod bearing is easy and also the best way to spot fragments at the bottom
The ticking could be a lifter from oil pressure problems from contamination f=rom the first event
Old Sep 17, 2008 | 10:43 AM
andreww238's Avatar
what was the problem... my plug looks exactly like the plug on page 1... im doing a compression test tonight..and probally pulling the head...the car runs and idles decent.. but once u give it a little throttle, especially with a load the car misses and backfires and runs like ****.. i drained the oil and no signs of fuel, savings, or anything of the sort.. maybe a valve failure im thinking.. maybe some debris is in the cylinder bouncing around on the piston and hitting the plug...causing the chips and the plug to get crushed down...
Old Sep 17, 2008 | 10:44 AM
andreww238's Avatar
bump for some advice
