Compression numbers help
Old Oct 3, 2007 | 03:02 PM
missionx96x's Avatar
Quick question guys. I just bought an evo last week and realized it had numbers on the valve cover that looked to be compression numbers. i did a little research on old sale reports and found out those were compression numbers. But is 180 155 155 180 good for an evo?
Old Oct 3, 2007 | 03:07 PM
CrackerJackToy's Avatar
Wow, trade the car back in, that is NOT good!
Old Oct 3, 2007 | 03:09 PM
[EVO]Cookie's Avatar
180 is good depending on the mileage. They should be within a couple of pounds from each other though. It might have worn rings in the center two cylinders or valves might be leaking if that's the case they can be reseated.
Old Oct 3, 2007 | 03:32 PM
thanks
Old Oct 3, 2007 | 03:33 PM
my brother is taking the car now to get a compression test so ill know soon
Old Oct 3, 2007 | 03:47 PM
rcefstsfecr's Avatar
Very Bad Very Very Bad! If they were all 180 or all 155 you'd be good. This is bad.
Old Oct 3, 2007 | 03:52 PM
C6C6CH3vo's Avatar
Who sold it to you?
Old Oct 3, 2007 | 04:05 PM
Specs say 138 minimum with no more than 14psi variation between ALL cylinders.
Yeah, you need to rebuild something.
Poopy
Mar 16, 2014 03:31 PM
tiggerx3
10
Jul 27, 2013 06:39 AM
kapolani
33
Apr 8, 2008 03:01 PM
h.funk
10
Oct 8, 2006 04:44 PM
ExViTermini
Jun 8, 2005 05:41 AM
