Why we love mitsu motors... ouchie!
Old Oct 4, 2007 | 03:56 PM
  #61
saiyanzzrage's Avatar
Originally Posted by VIPGarage
Ok, I have a problem with this and I hope I'm not out of line but there is another issue there. I don't see where there are any signs of an Alky issue but ofcourse I haven't seen the whole picture first hand. Chad is top notch but humor me for a second.....
I see the oil pump shaft separate from the front case. If you look at the pic below you will see that it's not in the pump assembly. The end of that shaft is flattened in a spot where it slides into the oil pump through the oil pump sprocket. I think the oil pump gave out some how. Whether it was do to previous work done or just failure (yeah folks, it happens)
funny thing is, the car wasnt even under boost when she blew, my cousin shifted into 4th, low rpms, and the second he stepped on it she let go...
Old Oct 4, 2007 | 04:34 PM
  #62
C6C6CH3vo's Avatar
20,000 miles on halfass failsafe and still waiting for it to burn up so I can upgrade to a new engine.
Might be longer now that 4 counts of knock (or whatever I set it to) automatically equals 15 psi using a modified tephra patch
Old Oct 4, 2007 | 04:36 PM
  #63
Evo_Jay's Avatar
Is that out???
Old Oct 4, 2007 | 06:07 PM
  #64
FYI, that brand new ix turbo and manifold you see on that crate motor is for sale...i will be posting a thread with a bunch of stuff for sale once i get the car back from Chad
Old Oct 4, 2007 | 06:13 PM
  #65
Originally Posted by CBRD
Al,
it looks as if the alky mix wasnt mixed properly.... using poor quality, or mixing with regular water... etc
cb
Chad, I was running 100 percent meth...
Old Oct 4, 2007 | 06:16 PM
  #66
Originally Posted by yasir
Hey CBRD, since u replaced the customer's motor altogether, how abt selling me his used alternator?? mine's going bad..
ill have a thread for everything thats being sold, namely the head from my old motor, the brand new turbo from the crate motor, etc
yasir, Chad told me about the alternator, its yours if you want it...has only 8500 miles on it
Old Oct 4, 2007 | 09:14 PM
  #67
VIPGarage's Avatar
First off I am glad that you were in such good hands! Looks like Chad came through for you in a big way.
Secondly it doesn't surprise me ONE BIT that you werent in it when it happened. You'd be amazed how often this is the case.
Old Oct 5, 2007 | 02:32 AM
  #68
EvoRecordSetter's Avatar
CB, how much did you pay for the crate motor? where did you get it?
Old Oct 5, 2007 | 04:25 AM
  #69
He sure did, I appreciate it very much
Old Oct 7, 2007 | 10:51 AM
  #70
Ricekiller81's Avatar
Hey John Iam glad your car ended up in good hands non the less the shop was close by. Iam also running 100% meth and thinking about de-tuning the car for that same reason. Enjoy the new transplant.
Old Oct 7, 2007 | 11:06 AM
  #71
jrsimon27's Avatar
are crate motors still available for evo8s?
Old Oct 7, 2007 | 11:08 AM
  #72
jrsimon27's Avatar
i would only use racegas to many blown engines using meth
Old Oct 7, 2007 | 06:49 PM
  #73
CBRD's Avatar
only evo ix crate motors...
cb
Old Oct 8, 2007 | 07:19 AM
  #74
thanks Jon...for my needs (driving the car 3 times a month lol) the exhaust, intake and tune at 23psi is plenty for me
Old Oct 8, 2007 | 02:21 PM
  #75
SIGSP2340's Avatar
If it wasn't under boost when the engine failure accrued then I don't think the meth injection is source of the problem. As most meth kits start injecting after a certain RPM or Boost Pressure. If this car wasn't even in boost or a full load and let loose. I would be curious as to what really happened???
Originally Posted by vwjeff
I dont care if it has fail safe or not... it can stiil Fu*K up, its electronicaly controlled.
With C16.... I know its there
Couldn't agree anymore. That's exactly how I feel.
