1100whp or Bust! this Monday
Old Oct 9, 2007 | 02:57 PM
  #151
jmartinez1170's Avatar
Originally Posted by ifarted2
65% duty at about 90psi of fuel pressure at 51 psi of boost
Nice. Alot of room left then. You should have no problem reaching your goal. Have you talked to VP about making something with more oct. then VP import. Im sure they can mix up a blend for your needs and goals.
Old Oct 9, 2007 | 03:03 PM
  #152
WestSideBilly's Avatar
El Jefe
Originally Posted by V.8MR
I'm sure he means if they deserved it, rather than look the other way solely because they contribute funds to the forum, which would be unethical.
More or less, yeah. This thread is a perfect example - a user is working on his project Evo, and vendors are using it as a platform to take cheap shots at each other.
I'm going to get slapped for going off topic.
Old Oct 9, 2007 | 03:04 PM
  #153
V.8MR's Avatar
OT for life!
<3
Old Oct 9, 2007 | 03:08 PM
  #154
Paul Nelson's Avatar
Originally Posted by evodan2004
well i hope you get 1101hp and run 8.40 at 171mph. g/l
Some of the things we are doing this winter to reduce weight is
1) make the front of the car Tube
2) No abs and brake booster. Going to count on my parachute to stop me
3) Take out the sound deadening
4) Put the AMS Carbon fiber roof in
5) Take out a ton of sheet metal
6) There is 3 layers of firewall take out 2 layers
7) Motorcycle brakes in the rear
8) Lexon windows
9) Remove the spray on coating under the car
10) Lose 35 lbs
Old Oct 9, 2007 | 03:09 PM
  #155
OT for life!
<3
Lmao
Dam taggers
Old Oct 9, 2007 | 03:13 PM
  #156
prostcj's Avatar
11 pages of posts and not one dyno post. Can I have my 10 minutes back please.
Old Oct 9, 2007 | 03:15 PM
  #157
If i could make time go faster i would. Cant dyno till thursday
Old Oct 9, 2007 | 03:33 PM
  #158
wshihdnevo's Avatar
8) Lexon windows
10) Lose 35 lbs
Paul, Remember to go 1051 on the evo when removing the under coating on the car...
Old Oct 9, 2007 | 04:39 PM
  #159
El Jefe
8) Lexon windows
10) Lose 35 lbs
I assume you've already removed the door beams and front/rear bumper reinforcement?
Edit: Looking at your list, I'm reminded of the SCC (?) project car from a few years ago, where they ended up with a frame and an engine.
Old Oct 9, 2007 | 05:03 PM
  #160
MaelstroM's Avatar
Paul, what about a liquid to air intercooler, or even a intercooler chiller?
I mean, 50+ psi is sure to have inlet temps pretty high...anything to lower that should theoretically increase power without increasing the chance of blowing up...
Old Oct 9, 2007 | 05:08 PM
  #161
Billy@EnglishRacing's Avatar
paul let me know when that sound deadening needs to come out... im all over it
Old Oct 9, 2007 | 05:26 PM
  #162
Robevo RS's Avatar
"I will give you an example, so we are clear this isn't just Paul. My good friend Al Friedman, for the last year or more I have heard Al complain about "someone else" being SO light and that's why they are kicking his butt. I have told Al countless times to either gut the car and make it light or just shut up, we all own race cars and non of these cars are worthy of street use or even being called EVo's at this point. An EVO is a great handling, comfortable, world class stopping car that can haul 5 adults around. A small 4 door with one/two seats, tiny brakes, no exhaust, no air bags, no door beams etc., etc. are not worthy of being called a real EVO, so just gut the damn thing and shut up and run it. I tell one of my good friends this, so saying it to anyone else.....................should be fine."
i'm totally agree about the point he makes here.
Old Oct 9, 2007 | 05:29 PM
  #163
wshihdnevo's Avatar
I thought it was over, apparently not so...
Old Oct 9, 2007 | 05:39 PM
  #164
Robevo RS's Avatar
i just try to steer... but i like that comment anyway
Old Oct 9, 2007 | 05:51 PM
  #165
What you do copy and paste what david said this morring. He said the same thing word for word
