Cam question
Old Oct 8, 2007 | 09:06 PM
blakevo8's Avatar
Cam question
Will an 03 evo see better hp increase than an 06 with 272 cams upgrade?
Old Oct 8, 2007 | 09:10 PM
ohthree's Avatar
than a stock 06 evo..? yes.
Old Oct 8, 2007 | 09:17 PM
blakevo8's Avatar
no no
03 evo tuned
now put in cams and retune...
06 evo tuned
will the 03 see a higher increase from cams upgrade aside from the whole mivec tuning? i know base flash 06 are better but will a 03 see better WHP increase than an 06?
Old Oct 8, 2007 | 09:23 PM
sparky's Avatar
I am not sure that you can make a direct comparison between a IX vs. an VIII concerning cams, since only the exhaust cams are interchangeable. VIII intake cams won't work in the Mivec head.
Old Oct 8, 2007 | 09:40 PM
chaotichoax's Avatar
the simple answer to your question...yes viii's take more liking to cams than ix's
mivec makes engineering a better cam than stock rather difficult or so it seems for the intake side of things
Old Oct 8, 2007 | 09:55 PM
Spazpilot's Avatar
being that the 9 cams are more aggressive because of the mivec yes the evo 8 will make more power.
Old Oct 9, 2007 | 10:24 PM
EiVxO's Avatar
8 wont make more power than 9 vs numbers when there done. 8 will just benefit more from cams.
Old Oct 10, 2007 | 07:35 AM
BenJ's Avatar
It would be close but I suppose that a good part of it would have to do with your tune.
Old Oct 10, 2007 | 09:35 AM
evo_what's Avatar
i would GUESS that the VIII will see higher gains from before the cams, but the overall hp number between the VIII and IX will be similar because the VIII has less power to begin with. because of the mivec, the IX might see a few less hp increase, but as i stated before, the ending result should be the same or similar.
-Chris
hutch959
10
Nov 25, 2016 05:35 PM
mission664
66
May 19, 2012 11:27 AM
sleeper04
Dec 20, 2010 12:17 PM
boostin@27
Jul 7, 2007 03:47 PM
Carrier
Lancer Engine Tech
Jan 9, 2007 09:56 PM
