Balance shaft removal how to?
Old Oct 15, 2007 | 06:47 PM
  #31
CO_VR4's Avatar
Geez.... do we have to spoon feed you everything?
http://www.amsperformance.com/store/...oducts_id=1550
Old Oct 15, 2007 | 10:21 PM
  #32
SPOOLEDTSiAWD's Avatar
i know thats the kit from ams. I was wanting to see how much needs to be taken off the oem shaft. but thanks
Old Oct 17, 2007 | 11:18 AM
  #33
Looking at the ams kit, everything that is red has to come off right?
Old Oct 18, 2007 | 10:17 AM
  #34
bump
Old Oct 18, 2007 | 10:33 AM
  #35
sabastian458's Avatar
Correct. all in red needs removed
Old Oct 18, 2007 | 10:35 AM
  #36
appreciate it took forever for somebody just to tell me that
Old Oct 23, 2007 | 09:06 PM
  #37
any issues in running a cut down shaft like this? Cam sucks so pics arent the greatest
Old Oct 24, 2007 | 09:27 AM
  #38
blackevo110's Avatar
Originally Posted by thebluesky
With the engine out of the car, this mod is cake. I too did it the hard way and did it with the engine still in the car, and it took quite a while as I had to fabricate a tool to ge the bearings out. Mitsubishi had a special tool for this but had discontinued it and was in teh process of replacing it with another one. Don't know if that tool ever came out.
32mm socket on an extension. of course i did that out of the car and with a mallet.
Old Oct 24, 2007 | 11:51 AM
  #39
barneyb's Avatar
Originally Posted by atlvalet
There are 2 schools of thought. One says balance shafts eliminate the harmonics endemic to all inline 4 cylinder engines. The other believes the fewer the parts, the less chance there is for something to break. There is also horsepower to be found by removing the balance shafts.
Also, the balance shafts rotate at twice engine speed. So, if there is any problem with oiling the balance shaft bearings are the first to go.
Old Oct 24, 2007 | 01:29 PM
  #40
any issues with the shaft like the one above
Old Oct 24, 2007 | 03:51 PM
  #41
EvoTech's Avatar
Just started breaking in the engine that I built with the removed rear balence shaft and the turned down front shaft. So far I cannot feel any vibration, but I have not beat it yet.
Old Oct 24, 2007 | 04:19 PM
  #42
thebluesky's Avatar
Holy overpriced parts, Batman!!!!!
In answer to your question about running a shaft like this, just the same issues as running a stubby shaft.
Old Oct 24, 2007 | 04:32 PM
  #43
what is it that makes the stubby shaft fail
Old Oct 24, 2007 | 06:39 PM
  #44
bump
Old Oct 25, 2007 | 09:25 AM
  #45
bump im thinking about using the other front cover i have with the cut off shaft
